Water hammer simulation in Fluent
Old   March 25, 2021, 17:13
Wink Water hammer simulation in Fluent
Purohit Parth
Parth0208 is on a distinguished road
I am trying to simulate water hammer effect in a pipe.
The condition is that, when I close outlet for 2 sec, then water hammer should occur. I am simulating 2 water hammer effects in 30 secs.
from 0 to 13 sec the inlet velocity is 2 m/s, from 13 to 15 sec it is 0, from 15 to 28 it is again 2 m/s, then again from 28 to 30 sec it is 0 m/s.
For this I have tried to write IF statement in UDF, but it is showing error.
BCs: @Inlet: Pressure inlet, @Outlet: Velocity inlet, @Wall: wall
Function that I wrote:
IF(13[s]<=t&&t<=15[s], 0[m/s], 2[m/s])
IF(28[s]<=t&&t<=30[s], 0[m/s], 2[m/s])
Kindly help me.
thank you
Parth0208 is offline   Reply With Quote
Old   April 2, 2021, 21:50
Yasser Selima
Yasser is on a distinguished road
I am assuming you have a typo in your boundary conditions ... but anyway, You don't need UDF .. you can use expression. If you want to use a UDF, you need to use DEFINE_PROFILE
Go to the UDF manual and look at the examples and try to modify one to fit your case. And if it doesn't work, bring it here and someone will help you for debugging
Yasser is offline   Reply With Quote
fluent - udf, udf code
looking for a smart interface matlab fluent chary FLUENT 24 June 18, 2021 09:07
Cfd simulation for water hammer phenomenon MihaiG CFD Freelancers 1 November 17, 2017 05:48
Ricardo Wave Water Injection Simulation randomspeedfreak Main CFD Forum 0 April 2, 2015 12:20
question about simulation of falling water film mengyue1 FLUENT 2 March 30, 2014 10:16
Getting the pressure waves in Fluent for a water hammer problem teopetre FLUENT 2 August 6, 2013 19:24
