UDF for shear stress
Old   May 18, 2021, 07:31
Post UDF for shear stress
PXY
pxy
PXY is on a distinguished road
Hello everyone,
I'm writing a code to define the wall shear stress, but it's always wrong. How to write it correctly?
τzx=-(σz*f+(ρ*g*vx^2)/ξ)
#include"udf.h"
#define F 0.3 /*friction coefficient*/
#define B 1000 /*turbulence parameter*/
#define D 1630 /*density*/
#define g 9.81
DEFINE_PROFILE(taux_profile, t, i)
real u, p;
face_t f;
Thread* t0;
cell_t c0;
begin_f_loop(f, t)
t0 = THREAD_T0(t);
c0 = F_C0(f, t);
p = C_P(c0, t0);
u = C_U(c0, t0);
F_PROFILE(f, t, i) = p * F + D * g * u * u / B;
end_f_loop(f, t)
DEFINE_PROFILE(tauy_profile, t, i)
real v, p;
face_t f;
Thread* t0;
cell_t c0;
begin_f_loop(f, t)
t0 = THREAD_T0(t);
c0 = F_C0(f, t);
p = C_P(c0, t0);
v = C_V(c0, t0);
F_PROFILE(f, t, i) = p * F + D * g * v * v / B;
end_f_loop(f, t)
PXY is offline   Reply With Quote
Old   May 19, 2021, 11:23
pakk will become famous soon enough
Please explain how you concluded that it's wrong.
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build".
pakk is offline   Reply With Quote
Old   May 19, 2021, 20:45
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
check values of P and V/U you are extracting from adjusted to wall cells
you may do it using Messages to console
p = C_P(c0, t0);
u = C_U(c0, t0);
Message0("u = %f, p = %f\n",u,p);
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   May 19, 2021, 23:55
PXY
pxy
Similarly, when I don't use UDF, the result is convergent, but when I add UDF, my result shows "floating point exception"
Old   June 5, 2021, 05:57
Initialize, don't run, plot the shear stress.
Is it what you expect?
Old   June 9, 2021, 01:14
PXY
pxy
Initialize but do not run, why is the shear stress a straight line equal to 0? Is my UDF written wrong?
I checked the units, length (m), Pressure (Pascal), but when I run it, it shows that the shear stress of wall is especially small.
How to validate udf for shear stress on a fluid cibi FLUENT 0 December 11, 2020 05:44
Fluent UDF Wall Shear Stress Segmentation Fault a1ananth Fluent UDF and Scheme Programming 3 February 24, 2015 03:23
Fluent UDF for interfacial stress in VOF rsingh7 Fluent UDF and Scheme Programming 0 July 18, 2014 16:54
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
