May 18, 2021, 07:31 |
UDF for shear stress
pxy
Rep Power: 5 |
Hello everyone,
I'm writing a code to define the wall shear stress, but it's always wrong. How to write it correctly? τzx=-(σz*f+(ρ*g*vx^2)/ξ) #include"udf.h" #define F 0.3 /*friction coefficient*/ #define B 1000 /*turbulence parameter*/ #define D 1630 /*density*/ #define g 9.81 DEFINE_PROFILE(taux_profile, t, i) { real u, p; face_t f; Thread* t0; cell_t c0; begin_f_loop(f, t) { t0 = THREAD_T0(t); c0 = F_C0(f, t); p = C_P(c0, t0); u = C_U(c0, t0); F_PROFILE(f, t, i) = p * F + D * g * u * u / B; } end_f_loop(f, t) } DEFINE_PROFILE(tauy_profile, t, i) { real v, p; face_t f; Thread* t0; cell_t c0; begin_f_loop(f, t) { t0 = THREAD_T0(t); c0 = F_C0(f, t); p = C_P(c0, t0); v = C_V(c0, t0); F_PROFILE(f, t, i) = p * F + D * g * v * v / B; } end_f_loop(f, t) } |
May 19, 2021, 11:23 |
Rep Power: 26 |
Please explain how you concluded that it's wrong.
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build". |
May 19, 2021, 20:45 |
Alexander
Rep Power: 34 |
check values of P and V/U you are extracting from adjusted to wall cells
you may do it using Messages to console Code:
p = C_P(c0, t0); u = C_U(c0, t0); Message0("u = %f, p = %f\n",u,p);
best regards ****************************** press LIKE if this message was helpful |
May 19, 2021, 23:55 |
pxy
Rep Power: 5 |
June 5, 2021, 05:57 |
Rep Power: 26 |
Initialize, don't run, plot the shear stress.
Is it what you expect?
June 9, 2021, 01:14 |
#6 | |
pxy
Rep Power: 5 |
I checked the units, length (m), Pressure (Pascal), but when I run it, it shows that the shear stress of wall is especially small. |
How to validate udf for shear stress on a fluid | cibi | FLUENT | 0 | December 11, 2020 05:44 |
Fluent UDF Wall Shear Stress Segmentation Fault | a1ananth | Fluent UDF and Scheme Programming | 3 | February 24, 2015 03:23 |
Fluent UDF for interfacial stress in VOF | rsingh7 | Fluent UDF and Scheme Programming | 0 | July 18, 2014 16:54 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 22:14 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 04:01 |
