UDF of saturation temperature
Old   June 13, 2021, 02:36
Default UDF of saturation temperature
Stanlee
stanlee8 is on a distinguished road
Hi there,
I am trying to simulate condensation in the building environment, using the evaporation-condensation model in Fluent.
Mixture multiphase model was used, with the primary phase as water liquid and a mixture of water vapour and air as a secondary phase.
I understand I need a UDF to describe the relationship between saturation temperature and water vapour pressure.
The UDF I used is listed below:
#include "udf.h"
DEFINE_PROPERTY(saturation_temp,c,t)
real sat_t;
real vapor_p;
real static_p = C_P(c,t);
real operating_p = RP_Get_Real ("operating-pressure");
vapor_p = static_p + operating_p; // absolute pressure = static pressure + operating pressure
sat_t = (1723.6425/(8.05573-((double)log10((double)vapor_p/133.322)))-233.08)+273.15; // Pressure in Pa to mmHg (Yaws)
return sat_t;
A transient model is used and the results diverged after 5 iterations.
The error is shown as below:
Experiencing convergence difficulties - temporarily relaxing and trying again...
Stabilizing pres
sure coupled to enhance linear solver robustness.
Stabilizing pressure coupled using GMRES to enhance linear solver robustness.
Divergence detected in AMG solver: pressure coupled Stabilizing phase-2-species-0 to enhance linear solver robustness.
Stabilizing phase-2-species-0 using GMRES to enhance linear solver robustness.
Stabilizing temperature to enhance linear solver robustness.
Stabilizing temperature using GMRES to enhance linear solver robustness.
temperature limited to 1.000000e+00 in 751264 cells on zone 10 in domain 1
temperature limited to 5.000000e+03 in 399712 cells on zone 10 in domain 1
Error at host: floating point exception
Error at Node 0: floating point exception
Error at Node 1: floating point exception
Error at Node 2: floating point exception
Error at Node 3: floating point exception
===============Message from the Cortex Process================================
Compute processes interrupted. Processing can be resumed.
Interrupting client...
Done.
Registering Udf, ("H:\rail humid_files\dp4\FLU\Fluent\sattemp1.txt")
Calculation complete.
It is really killing me, somebody please help me!!!
Thank you so much.
stanlee8 is offline   Reply With Quote
Old   June 13, 2021, 02:48
pakk will become famous soon enough
Does the same happen if you vaatwanden the relevant line to
sat_t = 300;
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build".
pakk is offline   Reply With Quote
Old   June 13, 2021, 06:41
Stanlee
Hi Pakk,
I am not sure if I have got you right, but I have tried the follows code:
#include "udf.h"
return (real)373.1545154;
which works well.
Old   June 13, 2021, 07:07
Stanlee
Hi Pakk,
yes, I just replaced
with
sat_t = 300;
and it works fine.
Old   June 13, 2021, 13:00
OK, then the problem is in that equation.
Is the pressure in your simulation within the range where that equation is valid?
Old   June 14, 2021, 23:22
Stanlee
Hi Pakk,
Yes, I guess so.
May I ask what static_p = C_P(c,t) represent?
Cuz I copy the code from somewhere else and not quite familiar with it.
Old   June 14, 2021, 23:30
Stanlee
If C_P(c,t) is the static pressure of the mixture, then I think the above UDF is wrong.
Cuz the saturation temperature is a function of partial vapour pressure but not the static pressure of the mixture, am I right?
Old   June 16, 2021, 04:01
The UDF implements a certain equation from physics. You have to say which equation should be implemented.
If you tell Fluent to use the wrong equation, then you will get the wrong results.
I can not tell you if the equation is wrong: you are the one who is doing the simulation, you are the one who decided that a certain equation should be used. So you are the one who should know how the equation should look like.
Old   June 27, 2021, 07:12
Stanlee
HI Pakk,
Thanks, I think I have already solved it!
UDF for saturation temperature for Lee's Condensation model Boo85 Fluent UDF and Scheme Programming 1 August 21, 2021 16:05
How to give the temperature condition by using the temperature of next cell in UDF? JuBong Fluent UDF and Scheme Programming 6 February 19, 2018 06:09
how can I access to static temperature in UDF? milmil FLUENT 0 September 19, 2017 08:29
UDF problem- time dependent temperature at inlet kaeran FLUENT 1 June 16, 2015 21:48
UDF slip and temperature jump from IFRT abir Fluent UDF and Scheme Programming 1 July 30, 2012 05:44
