May 8, 2022, 05:30 |
Unable to open file when loading UDF
Hi everyone, I'm trying to simulate 2D hybrid rocket combustion using an UDF for the inlet mass flow rate at the solid fuel boundary. When I compile the UDF (using the method involving the Visual Studio command prompt) everything works fine and fluent returns this:
Copied C:\Users\alera\OneDrive\Desktop\UDF/udf_rr_HTPB_gradFL.c to libudf\src Creating user_nt.udf file for 2ddp_host ... (system "copy "C:\PROGRA~1\ANSYSI~1\v192\fluent"\fluent19.2.0\src\udf\makefile_nt.udf "libudf\win64\2ddp_host\makefile" ") 1 file copied. (chdir "libudf")(chdir "win64\2ddp_host")# Generating ud_io1.h udf_rr_HTPB_gradFL.c # Generating udf_names.c because of makefile udf_rr_HTPB_gradFL.obj udf_names.c # Linking libudf.dll because of makefile user_nt.udf udf_names.obj udf_rr_HTPB_gradFL.obj Microsoft (R) Incremental Linker Version 14.29.30038.1 Copyright (C) Microsoft Corporation. All rights reserved. Creation of library libudf.lib and object libudf.exp Creating user_nt.udf file for 2ddp_node ... (system "copy "C:\PROGRA~1\ANSYSI~1\v192\fluent"\fluent19.2.0\src\udf\makefile_nt.udf "libudf\win64\2ddp_node\makefile" ") 1 file copied. (chdir "libudf")(chdir "win64\2ddp_node")# Generating ud_io1.h udf_rr_HTPB_gradFL.c # Generating udf_names.c because of makefile udf_rr_HTPB_gradFL.obj udf_names.c # Linking libudf.dll because of makefile user_nt.udf udf_names.obj udf_rr_HTPB_gradFL.obj Microsoft (R) Incremental Linker Version 14.29.30038.1 Copyright (C) Microsoft Corporation. All rights reserved. Creation of library libudf.lib and object libudf.exp Done. Then when I press load fluent prints this thing below and "crashes" (it doesn't close but basically becomes unusable and weird, commands are no more executed for example, I can't retry loading and the only way is to close the application): Code:
Opening library "C:\Users\alera\OneDrive\Desktop\UDF\libudf"... Library "C:\Users\alera\OneDrive\Desktop\UDF\libudf\win64\2ddp_host\libudf.dll" opened Unable to open file The fl process could not be started. MPI Application rank 0 exited before MPI_Finalize() with status -1073740791 I've already tried starting fluent in parallel and serial mode, in single and double precision, and basically searched through all internet but found nothing. Can someone please help me? I'm going crazy with this error. P.S. my Ansys version is 19.2 and my OS is windows 11 Thank you in advance |
May 8, 2022, 05:54 |
Solved: The problem was in the UDF itself that executed a piece of code that would force fluent to exit if a .txt input file was not present in the src folder. The error was so generic that I couldn't understand it. I wish my prof that gave me the UDF said me this beforehand .
Sorry for the bothering |
load error, udf, unable to open file |
[OpenFOAM.com] swak4foam compiling issues on a cluster | saj216 | OpenFOAM Installation | 5 | January 17, 2023 16:05 |
Using PengRobinsonGas EoS with sprayFoam | Jabo | OpenFOAM Running, Solving & CFD | 35 | April 29, 2022 15:35 |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 10:59 |
