July 29, 2021, 04:44 |
Convert transient case to steady state case
I'm working on simulating kinematics of insect wing flapping and I wrote a UDF for its transient kinematics which works fairly well. The problem is that I need to actually rework the simulation as a steady state case for my final results. My current code has a time component which does not get processed by Fluent as the case is steady state, as you may see below: /* flap.c */ /* UDF for specifying a simple harmonic motion*/ /* */ /**********************************************/ #include "udf.h" #define Freq 0.1 #define angular_freq 2.0*M_PI*Freq #define tetmax -45.0*M_PI/180 DEFINE_CG_MOTION(shm, dt, cg_vel, cg_omega, time, dtime) { real omega; omega = tetmax*angular_freq*cos(angular_freq*time); /* rotational speed about axis*/ cg_vel[0] = 0.0075 * sin(3.1415927 * time / 5.); cg_vel[1] = 0.0; cg_vel[2] = 0.0; cg_omega[0] = 0.0; cg_omega[1] = 0.0; cg_omega[2] = omega; } I need to know how I can change this code so it works in a steady state case as well. |
July 29, 2021, 05:41 |
Alexander
Rep Power: 34 |
motion itself implies something transient, isn't it?
if you need steady state simulation on specific configuration of domain, you may : 1. prepare this mesh from the very beginning and run it as steady state 2. or stop your transient simulation at specific moment probably you have special knd of problem, which I don't fully understand
best regards ****************************** press LIKE if this message was helpful |
Transient simulation gives worse results than steady state simulation | jgross | CFX | 12 | January 21, 2021 12:21 |
Transient and Steady state simulation results do not match | shahin1 | FLUENT | 0 | July 23, 2020 07:24 |
[DesignModeler] DesignModeler Scripting: How to get Full Command Access | ANT | ANSYS Meshing & Geometry | 53 | February 16, 2020 15:13 |
how to map results from steady state run to tranient case? | phsieh2005 | OpenFOAM Running, Solving & CFD | 2 | November 7, 2010 06:20 |
About the difference between steady and unsteady problems | Lisa | Main CFD Forum | 11 | July 5, 2000 14:37 |
