strain rate magnitude
Like Tree11Likes
Old   July 21, 2011, 05:58
Smile strain rate magnitude
Rakesh
rakadit is on a distinguished road
Dear All!
what is the correct definition for finding strain rate magnitude?
in Fluent. in Flunent ,STRAIN-RATE-MAG(c,t) is defined as:
strain_rate_mag(c,t) = sqrt[[C_DUDX(c,t)*(C_DUDX(c,t)+C_DUDX(c,t))+C_DUDY(c,t)* (C_DUDY(c,t)+C_DVDX(c,t))+C_DUDZ(c,t)*(C_DUDZ(c,t) +C_DWDX(c,t))]+ [C_DVDX(c,t)*(C_DVDX(c,t)+C_DUDY(c,t))+C_DVDY(c,t)* (C_DVDY(c,t)+C_DVDY(c,t))+C_DVDZ(c,t)*(C_DVDZ(c,t) +C_DWDY(c,t))]+ [C_DWDX(c,t)*(C_DWDX(c,t)+C_DUDZ(c,t))+C_DWDY(c,t)* (C_DWDY(c,t)+C_DVDZ(c,t))+C_DWDZ(c,t)*(C_DWDZ(c,t) +C_DWDZ(c,t))]];
is the above definition correct .please elaborate on this?
Thanks ,
Rakesh
rakadit is offline   Reply With Quote
Old   July 21, 2011, 15:42
Amir's Avatar
Amir
Amir is on a distinguished road
the compact form is:
\sqrt{2*D:D}
which is:
\sqrt{2*DijDij} ; i,j=1,2,3 (two inner products)
D : strain rate tensor
sadjad.s and alainislas like this.
Amir is offline   Reply With Quote
Old   July 23, 2011, 03:18
Smile starin rate
Rakesh
Dear Sir,
Thanks for your quick response.
it would be great help If you elaborate a liitle more.
is sqrt(Dij Dij) =sqrt(e11^2+e12^2+e13^2+e21^2+......and so on).
here e11 etc.means 9 strain rate components.
but then how is it equivalent to the relation given in Fluent manual as S^2=delu/delx*(e11)+delu/dely*e12)+delu/delz*(e13)+................and so on.
Thanks ,
Rakesh
Old   July 23, 2011, 04:43
Amir's Avatar
Amir
Dear Rakesh,
In Mathematics, the magnitude of a second order tensor is defined as \sqrt{T:T}, but here, as you said, we have a convention for shear strain magnitude in which an extra constant coefficient is multiplied, so:
strain rate magnitude= \sqrt{2*D:D}=\sqrt{2*D^{2}_{11}+2*D^{2}_{12}+...}
Note that it is equivalent with FLUENT manual interpretation: (after some manipulations)
s=\sqrt{2u^{2}_{x}+2v^{2}_{y}+2w^{2}_{z}+(u_{z}+w_{x})^{2}+(u_{y}+v_{x})^{2}+(w_{y}+v_{z})^{2}}
Amir
Old   July 26, 2011, 11:05
Thumbs up
Rakesh
Dear Sir,
Thank you very much.
Rakesh
Old   September 20, 2012, 05:00
Unneoetech
The term you mention is usually defined as the shear rate. Is in Fluent the shear rate and the strain rate equal for Non-Newtonian flow?
Old   September 20, 2012, 10:26
Amir's Avatar
Amir
Dear friend,
These are two different concepts. Strain rate contains both shear and normal rates; you can consider strain rate as rate of deformation where the shear rate is just one part of that.
The strain rate tensor is extracted from gradient of velocity field while the fluid type just affects the constitutive relation (relation between stress and rate of strain) so these definitions can be used for each type.
Bests,
hulli likes this.
Amir
Old   September 20, 2012, 10:37
Unneoetech
Hi Amir,
That is just what I found out a couple of seconds ago It is also described in the Fluent manual in Section 30.4
http://hpce.iitm.ac.in/website/Manua...219.htm#217910
Strain Rate (in the Derivatives... category) relates shear stress to the viscosity. Also called the shear rate ( in Equation 8.4-17), the strain rate is related to the second invariant of the rate-of-deformation tensor . Its unit quantity is time-inverse. In 3D Cartesian coordinates, the strain rate,, is defined as Eq. (30.4-30)
Thanks for your fast answer!
Old   September 20, 2012, 10:44
Amir's Avatar
Amir
Hi Amir,
Yes I've seen that.
What I said was the definition in continuum mechanics but in FLUENT some definitions have changed! e.g., wall shear stress is wall traction!
Bests,
Amir
Old   September 25, 2012, 04:52
Naimah
wanna88 is on a distinguished road
Hi Amir,
So is that means in the Fluent, the strain rate equal to shear rate?
Thank you.
Regards,
Naimah
wanna88 is offline   Reply With Quote
Old   January 10, 2013, 07:43
Default mean shear rate
  #11
Michael Rembe
rembe is on a distinguished road
I'm not a expert in fluid mechanics. Can you tell me the difference between the strain rate magnitude:
and the mean strain rate:
Sij=1/2*(dUi/Dxj+dUj/dxi)
I need th correct formulation in the SMAGORINSKY-model.
Thank you very much
Michael
rembe is offline   Reply With Quote
Old   August 17, 2014, 17:37
Kanarya is on a distinguished road
Dear Amir,
I would like to calculate in UDF daviatoric part of strain rate tensor so definition of it as following:
S_prime_ij=S_ij - S_mm*kronecker_delta_ij/3,
so the part of kronecker_delta_ij is confused me…I must again calculate the magnitude if the S_prime as you explained in this thread or it is different?
thanks in advance!
Originally Posted by Amir View Post
Dear Rakesh,
Amir
Kanarya is offline   Reply With Quote
Old   August 18, 2014, 08:33
Amir's Avatar
Amir
Originally Posted by Kanarya View Post
Dear Amir,
thanks in advance!
No, this is quite straight-forward! Just substitute the S_mm term with sum of the diagonal components.
i.e., S_mm=S11+S22+S33
kronecker_delta_ij=0, where i/=j
kronecker_delta_ij=1, where i==j
Bests,
Amir
Old   August 19, 2014, 09:01
thanks Amir!
I am trying to define tensor in UDF but sth is wrong with the code or udf...
PHP Code:
real puixj[ND_ND][ND_ND];
puixj[0][0]= C_DUDX(c,t);
puixj[1][0]= C_DVDX(c,t);
puixj[0][1]= C_DUDY(c,t);
puixj[1][1]= C_DVDY(c,t);
for(
j=0;j<ND_ND;j++)
for(
i=0;i<ND_ND;i++)
Og[i][j]=0.5*(puixj[i][j]-puixj[j][i]); //Og is the rotation tensor
when I am putting random number to i or j it gives some results which is wrong!For example;even Og[25][20] is giving some result ....
do you know what is the problem here?
thanks in advance!
Bests,
Old   August 19, 2014, 10:40
Amir's Avatar
Amir
thanks in advance!
I guess, proper definition of the Og tensor as Og[ND_ND][ND_ND] and an initialization of this tensor may fixed this issue! However, I wonder how your UDF may lead to such error during the calculation!
Actually, forcing wrong indices to a matrix may result in previously saved and irrelative data in the memory.
Bests,
Amir
Old   August 21, 2014, 06:52
Hi Amir,
thanks for the answer!
But I am still getting weird values ...
For example I trying to define kronecker delta like:
PHP Code:
for(jj=0;jj<ND_ND;jj++)
for(
ii=0;ii<ND_ND;ii++)
if (
ii==jj)
delta[ii][jj]=1;
else
delta[ii][jj]=0;
and print
it out with:
Message("delta: %g/n",delta[ii][jj]);
the result is always "0"
Do you have any idea what is wrong with it?
thanks in advance!
Bests,
Old   August 21, 2014, 07:48
Amir's Avatar
Amir
Hi Amir,
PHP Code:
for(
ii=0;ii<ND_ND;ii++)
if (
ii==jj)
delta[ii][jj]=1;
else
delta[ii][jj]=0;
and print
it out with:
thanks in advance!
You need to put the Message command inside your loop, not out of that!
Moreover, this is "\n" not "/n".
Bests,
Amir
Old   August 21, 2014, 08:48
thanks Amir,
it seems it is fine now
Best!
Bests,
Old   August 25, 2014, 14:28
Hi Amir,
I have problem with convergence now.
It seems residuals are fine but the simulation is stopped.
PHP Code:
Updating solution at time levels N and N-1.
 done
iter  continuity       u-gas     u-solid       v-gas     v-solid       uds-0       uds-1    vf-solid     time/iter
9481 solution is converged
  9481  7.9111e-04  1.2569e-06  8.8861e-08  6.0119e-07  7.8996e-09  2.7750e-07  2.6720e-07  3.6096e-07  0
:00:02  100
Re
0
reyp
0
  9482  2.0487e-03  1.0965e-05  1.4955e-05  3.5806e-06  3.8082e-06  2.1239e-04  2.2740e-04  1.4775e-05  0
:00:02   99
Re
0
reyp
0
  9483  1.8130e-03  4.3936e-06  4.6505e-06  1.4881e-06  1.1923e-06  7.8683e-06  6.0966e-06  7.5522e-06  0
:00:02   98
Re
0
reyp
0
# Divergence detected in AMG solver: uds-1 -> Increasing relaxation sweeps!
Divergence detected in AMG solveruds-1
uds-1
uds-1
uds-1
uds-1
uds-1
uds-1
uds-1
Warning
An error or interrupt occurred while reading the journal file.
Some commands may not have been completed.
Halting due to end of file on input
Do you have any idea about it?
thanks in advance!
Bests,
Old   August 29, 2014, 17:53
do you think the problem is coming form the tensor which I have posted in thread 14?
may opposite indices are giving the same result?
thanks in advance!
thanks in advance!
Hi Amir,
PHP Code:
 done
:00:02  100
Re
0
reyp
0
:00:02   99
Re
0
reyp
0
:00:02   98
Re
0
reyp
0
uds-1
uds-1
uds-1
uds-1
uds-1
uds-1
uds-1
Warning
thanks in advance!
LinkBacks (?)
LinkBack to this Thread: https://www.cfd-online.com/Forums/fluent-udf/90818-strain-rate-magnitude.html
Posted By For Type Date
what is strain rate_Baby's home This thread Refback May 8, 2015 15:37
strain rate in UDF Paulina FLUENT 11 November 20, 2014 03:06
strain rate magnitude ahmadbakri STAR-CCM+ 1 June 3, 2010 13:03
Strain rate. MM? Main CFD Forum 1 February 15, 2006 08:55
strain rate at arbitrary position in a cell K. Kevala FLUENT 0 February 4, 2004 17:14
