Integration of radiation field with Discrete Phase Model |
October 1, 2021, 13:59 |
Hamed
Rep Power: 8 |
Hi All,
I want to simulate the movement of a particle in a room with the use of the discrete phase model (DPM) and obtain its trajectory. Meanwhile, there is a radiation field in the room. I need to define a function by integrating the local incident radiation and particle tracking time step. However, I cannot model the radiation field by Fluent. Last edited by hamed1387; October 8, 2021 at 15:15. |
October 5, 2021, 01:05 |
Alexander
Rep Power: 34 |
radiation field generates heat source in your case, isn't it?
if yes, all you need is to apply additional heat source using UDF (which could be coordinate dependent or uniform, or whatever)
best regards ****************************** press LIKE if this message was helpful |
October 5, 2021, 09:46 |
#3 | |
Hamed
Rep Power: 8 |
Hi AlexanderZ, Thank you for your time. Last edited by hamed1387; October 8, 2021 at 15:12. |
October 7, 2021, 00:01 |
Alexander
Rep Power: 34 |
Unfortunately, I have very limited experience with DPM simulations.
The only thing I can recommend is to read ansys fluent customization manual Look for Discrete Phase Model (DPM) DEFINE Macros
discrete phase model, radiation dose, radiation field, udf code |
Access phase fraction field in a phase change model | hend | OpenFOAM Programming & Development | 0 | October 17, 2019 05:03 |
Spray Modelling within the Discrete Phase model | Jufri | FLUENT | 2 | March 18, 2015 04:17 |
iteration questions in discrete phase | iknowjesus | FLUENT | 4 | March 13, 2015 06:07 |
Discrete Phase Model - URGENT!! | KS | FLUENT | 0 | October 29, 2008 12:19 |
Discrete Phase Model - Particle Tracking | johnnyb | FLUENT | 0 | March 17, 2004 09:36 |
