Fluent UDF urgent! Variable reaction rate
Like Tree2Likes
  • 1 Post By KristianEtienne
  • 1 Post By Boniface Omar
Old   July 4, 2011, 16:48
Default Fluent UDF urgent! Variable reaction rate
Nathan
natantyt is on a distinguished road
Hi
I've written a UDF in Fluent for a volumetric reaction rate. I want to know how I can make the reaction rate variable along my reactor due to variation in catalyst activity. Any idea?
Example:
r= p* k C^2 ( p is a function of distance into the reactor)
How do you implement this, I'm new to UDf
Thanks
natantyt is offline   Reply With Quote
Old   July 6, 2011, 05:24
Kristian Etienne Einarsrud
KristianEtienne is on a distinguished road
I guess what you need is a function which gives you the position of the each cell center, which is C_CENTROID(x,c,ct). Here, x is an array which holds the x,y,z coordinates, while c and ct are the cell and thread pointers which are passed from the solver through an appropriate macro.
Assuming you are using a DEFINE_ADJUST macro to update your reaction rate, and that your reaction rate is r=x*k*C^2 (x being the x-coordinate), I would use
DEFINE_ADJUST(adjustRXR,domain)
Thread *ct;
cell_t c;
real x[ND_ND];
real k, C,r,pos;
k=0.25; /* just an example*/
C=0.1; /* just an example*/
r=0.0; /* initialization to be sure*/
pos=0.0; /* initialization to be sure*/
thread_loop_c(ct,domain) /*Loop over the threads in the domain*/
begin_c_loop(c,ct) /*Loop over all cells in the thread*/
C_CENTROID(x,c,ct); /*Find position of cell and store in x*/
pos = x[0]; /*Store the x-coordinate as pos. y-coordinate is x[1],
z-coordinate is x[2]*/
r=pos*k*C*C; /*Store reaction rate in local variable r*/
C_UDMI(c,ct,0) = r; /*Store reaction rate in user defined memory position 0 so that other functions can access it*/
}end_c_loop(c,ct)
You will need one UDM to store the reaction rate if you do it in this way. Remember to hook the DEFINE_ADJUST function before running your simulations.
For a more complete example, see section 2.3.22.3 in the UDF-guide.
Good luck!
-KE
KristianEtienne is offline   Reply With Quote
Old   July 6, 2011, 16:36
Nathan
Thanks A lot for the comment
The problem is my reaction is defined through a volumetric reaction rate DEFINE_VR_RATE , the reaction needs the temperature and mass fraction of each node (300000 nodes) at each iteration. Apparently inside the ADJUST udf we don't ahve access to node values. I get error. Below is my original UDf for VR_Rate, if you like take a look at it.
#include"udf.h"
DEFINE_VR_RATE(proprate,c,t,r,mw,yi,rr,rr_t)
/*mass fraction of species i */
real y_c3h8=yi[3];
real y_h2o=yi[4];
real y_h2=yi[0];
real y_co=yi[1];
real y_co2=yi[2];
real y_n2=yi[5];
real Nsum, R, Keq1, T_w, r1,r2;
/*calculate species i in the unit of kgmol i/kg mix*/
y_c3h8 *= 1/mw[3];
y_h2o *= 1/mw[4];
y_h2 *= 1/mw[0];
y_co *= 1/mw[1];
y_co2 *= 1/mw[2];
y_n2 *= 1/mw[5];
Nsum = y_c3h8+ y_h2o + y_h2 + y_co + y_co2 + y_n2;
y_c3h8 *= 1/Nsum;
y_h2o *= 1/Nsum;
y_h2 *= 1/Nsum;
y_co *= 1/Nsum;
y_co2 *= 1/Nsum;
y_n2 *= 1/Nsum;
R=8.314;
T_w=C_T(c,t);
Keq1=pow(10,(2073/T_w)-2.029);
if(STREQ(r->name, "reaction-1")){
/*unit for rr, kg/m3s*/
r1= 44*3e8*exp(-105000/(R*T_w))*(y_c3h8*y_h2o)/(1+105*exp(3000/(R*T_w))*pow(y_c3h8,2));
*rr = r1;
elseif (STREQ(r->name, "reaction-2")){
r2= 28*3.4e9*exp(-130000/(R*T_w))*(y_co*y_h2o-(y_h2*y_co2)/Keq1) ;
*rr = r2;
Old   July 7, 2011, 03:59
Hello again,
If I understand your original post correctly, your problem is that you want to include a position dependency in your DEFINE_VR_RATE?
This can be done by the following modification (I have made my changes in bold text for clarity):
#include"udf.h"
real Nsum, R, Keq1, T_w, r1,r2,x[ND_ND],xpos,ypos,zpos;
real y_c3h8=yi[3];
real y_h2o=yi[4];
real y_h2=yi[0];
real y_co=yi[1];
real y_co2=yi[2];
real y_n2=yi[5];
/* Find and store coordinates for each cell*/
C_CENTROID(x,c,t); /* store position in array x*/
xpos = x[0];
ypos = x[1];
zpos = 0.0;
#if RP_3D
zpos = x[2];
#endif
/* The above #if statement ensures that you only can access the z-position (x[2]) if you are doing a 3D-simulation */
/* The coordinates of each cell are now stored in xpos,ypos and zpos (if 3D) for future use*/
y_c3h8 *= 1/mw[3];
y_h2o *= 1/mw[4];
y_h2 *= 1/mw[0];
y_co *= 1/mw[1];
y_co2 *= 1/mw[2];
y_n2 *= 1/mw[5];
y_c3h8 *= 1/Nsum;
y_h2o *= 1/Nsum;
y_h2 *= 1/Nsum;
y_co *= 1/Nsum;
y_co2 *= 1/Nsum;
y_n2 *= 1/Nsum;
R=8.314;
T_w=C_T(c,t);
*rr = r1;
*rr = r2;
Another point; note that the values you are using are *not* node values but *cell* values, as it is the cell pointer "c" which is passed from the macro DEFINE_VR_RATE.
Happy simulating!
-KE
soheil_r7 likes this.
Old   March 14, 2016, 15:53
Default Calcination Reaction
Diogo
tabirense is on a distinguished road
Hello all, first of all i would like to introduce myself as new on this field... I've read your posts and i have some doubts... How do you access the molecular weight of each component?? Have you defined it previously?? Because i coudn't realise where are these values on your program line...
Another doubt is about making an User Defined Function for this reaction:
caco3=cao+co2
I'm simulating a rotary kiln used for calcination... I need to compilate this reactions in the Fluent but i have no idea about how to do this... Can anyone help me??
Thank you in advance
tabirense is offline   Reply With Quote
Old   July 25, 2016, 08:17
Omar
Boniface Omar is on a distinguished road
Hello
Can someone please help me write a FLUENT UDF the reaction below which is defined by reaction rate equation of (R) below
CO+3H2=>CH4+H2O
R=k exp (E/RT)*(Pco^m*Ph2^n)
Where:
R is the volumetric reaction rate
k is Rate constant
E is Activation energy for reaction
R is Universal gas constant
T is Temperature
Pco is Partial pressure of carbon monoxide
Ph2 is Partial pressure of hydrogen
m is Power for CO partial pressure
n is Power for H2 partial pressure
Thank you.
hesamna likes this.
Boniface Omar is offline   Reply With Quote
Old   June 4, 2018, 01:26
Default Reactions between gas and liquid phase in porous media
soumendu.dasgupta is on a distinguished road
Hello all,
I am modeling a gas liquid reaction in a porous media: ArS+H2=Ar+H2S
I have written the udf for porous media. It is working fine. Then I wrote the following VR-rate udf for reaction and loaded in the function hooks. I have defined the stoichiometric coefficients of all species in the phase interaction panel and disabled heterogeneous stiff chemistry and set the reaction rate to none (since I am defining it in the function hooks). However, there is no change in reactant or species concentration and the entire flow proceeds without any species transport. The udf is compiled and loaded witthout any error. This is the udf:
#include "udf.h"
#include "mem.h"
#define KHDS 0.005083992078
DEFINE_VR_RATE(vol_reac_rate,c,t,r,mole_weight,spe cies_mf,rate,rr_t)
real kad=50000;
begin_c_loop(c,t)
real X_ars=C_YI(c,t,3)*C_R(c,t);
real X_h2=C_YI(c,t,1)*C_R(c,t);
real X_h2s=C_YI(c,t,0)*C_R(c,t);
if (FLUID_THREAD_P(t) && THREAD_VAR(t).fluid.porous)
*rate = ((-KHDS)*(pow(X_ars,1.6))*(pow(X_h2,0.56)))/(1+(kad*X_h2s));
else
*rate = 0;
*rr_t = *rate;
end_c_loop(c,t)
I will be extremely grateful if someone could kindly help me with this.
Thanks.
soumendu.dasgupta is offline   Reply With Quote
Old   November 18, 2020, 23:43
hesam
hesamna is on a distinguished road
Originally Posted by Boniface Omar View Post
Hello
CO+3H2=>CH4+H2O
Where:
k is Rate constant
T is Temperature
Thank you.
Hello dear
Did you find how we can write UDF for reactions like what you mentioned?
Thanks for your help
hesamna is offline   Reply With Quote
Old   October 17, 2021, 03:35
mickbatti is on a distinguished road
caco3=cao+co2
Hi tabirense,
I came across the same problem, wrote a udf for the heteregeneous reaction rate, but the code diverges quite soon, in any test I made.
I tested also the stiff chemistry solver to aid convergence and stability.
But with no success so far.
Have you figured out how to approach this?
Thanks
mickbatti is offline   Reply With Quote
using rate equation for volumetric reaction byronsmith FLUENT 4 April 14, 2019 12:28
A Problem of Fluent Interpreted UDF: parse error knight Fluent UDF and Scheme Programming 25 August 16, 2018 10:26
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
case files UDF volumetric reaction rate Marie-Anne Main CFD Forum 2 February 24, 2006 09:43
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 00:07
