UDF for vapor pressure
Old   May 18, 2017, 07:22
Default UDF for vapor pressure
Anuja Vijayan
anuarun is on a distinguished road
Hello friends,
I have a temperature profile file (not udf but boundary profile in tabular form)as my wall BC. I thought my profile file is working fineas I get the expected Temperature change at wall from T plots after convergence. I have written a UDF to vary vapour pressure as a function of temperature. I have hooked it to the vapour pressure option while activating mass transfer from liquid to vapour>cavitation. It gets interpreted neatly and solution converges also.Now, the solution obtained is not showing the expected improvement (rather change) when compared to a case where Pv=const.
My UDF looks like this.
#include "udf.h"
/*for Vapour pressure*/
DEFINE_PROPERTY(Vapour_pressure,c,t)
real T = C_T(c,t);
real p_v;
p_v = (0.00329*exp(0.19039*T) - 0.05762)*1000000.0;
return p_v;
How will I know if this is working fine? Do I need to write the UDF specifically in terms of SUB_THREAD, SUPER_THREAD etc. I assumed that since I am calling UDF from vapour pressure options, it will take appropriately. Is that right?
To check if it is a problem with the UDF, I changed vapour pressure to a polynomial fit and temperature as explained before(as boundary profile)and tried. This is not working either. Now I doubt whether I can give Twall as boundary profile. How to confirm this? Fluent user's manual and udf manual are so abstract on this topic. Is there any source from which I can read more on boundary profile and udf for vapour pressure?
Has anybody done something similar? Any help is greatly appreciated.
PS:edited title and re-posted a previous thread material to get better visibility. Pardon me if it caused any inconvenience.
anuarun is offline   Reply With Quote
Old   May 18, 2017, 09:28
Default vapour pressure change not accepted by Fluent
Anuja Vijayan
Simulation_check1: Vapour pressure kept constant; energy equation switched ON with a UDF written for Twall.
Result: Predicted inlet temperature matched with experiment. Plotted wall temperature showed correct profile.
Simulation_Check2: Energy OFF; vapour pressure was assigned a real constant value using a UDF.
Result: Plotted pressure profile showed 3.5 bar inlet pressure instead of the expected 2.5 bar.
Simulation_check3: Enenry ON; Pv defined as piecewise linear.
Result: Plotted pressure profile showed 3.3 bar inlet pressure instead of the expected 2.5 bar.
Previously when vapour pressure was constant and Energy eqn OFF, I got the correct inlet pressure. The moment I change vapour pressure from constant value, something is going haywire. Any solution?
Old   October 10, 2019, 04:21
Dnyanesh Mirikar
DnyanMiri is on a distinguished road
Did you able write correct UDF for vapor pressure? If you have, could you please share it with me? much appreciated. dnyansohm@gmail.com
DnyanMiri is offline   Reply With Quote
Old   October 21, 2019, 08:17
Anuja Vijayan
yes, I got the vapour pressure UDF correctly. I have sent that to you by email.
Old   January 24, 2020, 20:08
CWL
cwl6750084 is on a distinguished road
I wonder if you would mind sharing your UDF function as well. I have been struggling of it.
cwl6750084 is offline   Reply With Quote
Old   February 4, 2020, 06:27
Default Vapour pressure udf
Anuja Vijayan
Please give your mail id.
Old   May 20, 2020, 20:54
Hyungyu Lee
Hyungyu Lee is on a distinguished road
Could you please share it with me? much appreciated
aerogyu@gmail.com
Hyungyu Lee is offline   Reply With Quote
Old   July 2, 2020, 20:59
wugui Jiang
jiangwugui is on a distinguished road
Could you send a copy to me. Thanks very much.
jiangwugui@gmail.com
jiangwugui is offline   Reply With Quote
Old   July 14, 2020, 13:02
Arun raj.S
arunraj is on a distinguished road
could you share the udf kindly. arunraj.v2009@gmail.com
arunraj is offline   Reply With Quote
Old   March 3, 2021, 08:16
hanzao
leozhan is on a distinguished road
Could you share this udf with me? My email is leo.insa.lyon@gmail.com
Thanks a lot
leozhan is offline   Reply With Quote
Old   December 18, 2021, 05:57
Jakubano is on a distinguished road
Would you be kind enough to send me this UDF? Here's my email:
Thanks!
Jakubano is offline   Reply With Quote
Old   December 23, 2021, 11:04
djing is on a distinguished road
please Could you share the udf with me ? thanks
My email is belkacemidjelloul@gmail.com
djing is offline   Reply With Quote
Old   December 24, 2021, 10:12
pakk will become famous soon enough
Whoever reads this and has this UDF, please post it below here. Otherwise, people will continue to post their email addresses here, and spammers will find them.
If after my message somebody still puts their email address below, those persons are not very smart.
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build".
pakk is offline   Reply With Quote
UDF Compilation Error - Loading Library - COMMON Problem! Help! robtheslob Fluent UDF and Scheme Programming 8 July 24, 2015 00:53
Parallelize UDF? Which kind of UDF? Lilly FLUENT 5 March 25, 2014 02:05
Help! Delete the UDM codes in the UDF Messi Fluent UDF and Scheme Programming 2 January 28, 2014 09:01
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
