Xu & Froment methane steam reforming UDF
Old   December 23, 2010, 04:12
Default Xu & Froment methane steam reforming UDF
Sungjong Jo
eeheehee is on a distinguished road
Hi.
I'm trying to make a UDF about steam reforming using Xu & Froment equation ("Methane Steam Reforming, Methanation and Water-Gas Shift:I.Intrinsic Kinetics")
My problem is unit conversion.
Xu & Froment's rate constant has a unit of (kmol/kg/h).
and
DEFINE_VR_RATE macro guide said that macro has return value of (kgmol/m^3/sec)
what should i do to make it fit in Fluent format.
i tried
1. cell density
2. cell density*(sum of each reaction's reactants mole fraction)
it does not match up with reference value.
anybody who has experience about steam reforming UDF give me some advice,plz.
eeheehee is offline   Reply With Quote
Old   January 26, 2012, 07:49
Kerem Aksakal
pürtelaş is on a distinguished road
sorry for late reply, but is there any possibility that you miss the fact that, reaction rate in Xu and Froment is for per kg catalyst rather than per m^3. That means it should be taken as a surface reaction or should be taken into account as porous region. (very thin catalyst thickness which is defined as porous region will do the job.)
pürtelaş is offline   Reply With Quote
Old   April 3, 2014, 22:46
Li Jiageng
LiJG is on a distinguished road
Originally Posted by eeheehee View Post
Hi.
and
i tried
1. cell density
Hello:
Have you solved this problem? Recently, I have the same question as you. I want to use Xu & Froment equation to make a UDF in fluidized bed and face the unit convertion problem.
LiJG is offline   Reply With Quote
Old   June 6, 2014, 23:18
Sungjong Jo
I couldn't solve the problem.
Instead I used other equation that converted from Xu&Froment rate equation into Arrhenius equation.
It was research paper written in Korean. "A Comparative Study for Steam-Methane Reforming Reaction Analysis Model" (You can find it from "www.dbpia.co.kr")
This paper compared the original Xu&Froment equation written in UDF with three Arrhenius coefficient modified model.
Arrhenius coefficient modified model approximately well followed conversion rate graph of original equation but this paper recommended UDF method.
Because it was more accurate.
Anyway I used model 3 coefficient model.
I don't know it will help for your problem. But it could be alternative solution.
<REFORMING EQUATION>
Equation 1. CH4 + H2O ↔ CO + 3H2
Equation 2. CH4 + 2H2O ↔ CO2 + 4H2
Equation 3. CO + H2O ↔ CO2 + H2
<ARRHENIUS EQUATION>
Ki = Ai * T^(Bi) * exp(-Ei/RT)
<Reaction coefficient for three Arrhenius type reaction models>
model 1
Eq. (1) Ei : 2.40×108 // Ai : 9.490×1016 // Bi : 0
Eq. (2) 2.439×108 // 2.290×1016 // 0
Eq. (3) 6.413×107 // 4.390×104 // 0
model 2
Eq. (1) 2.40×108 // 4.745×1014 // 0
Eq. (2) 2.439×108 // 1.145×1014 // 0
Eq. (3) 6.413×107 // 2.195×102 // 0
model 3
Eq. (1) 2.40×108 // 6.811×1035 // -7
Eq. (2) 2.439×108 // 1.145×1014 // -4
Old   November 11, 2014, 18:37
Franchijio is on a distinguished road
Li Have you rectified how to sort the issues with XU and Froment rate equation in your fluidized bed as I have similar problem. I thought about multiplying the rate with the density of catalyst
kmol/Kg-cat/s x Kg/m3. this will change the rate to kmol/m3/s.
what do you or anyone think of this method for a fluidized bed system. Please really need your replies and support urgently.
Thanks
Franchijio is offline   Reply With Quote
Old   May 24, 2016, 04:18
flappy is on a distinguished road
Hi.
and
i tried
1. cell density
i know this case is old, nevertheless:
In my case I treat the fixed catalyst bed as homogenous. This enables me to convert the units by just multiplying with the total mass of catalyst in my reactor, divide it by the volume of the catalyst bed and by 3600.
does this help?
flappy is offline   Reply With Quote
Old   August 27, 2022, 01:54
Vinay Chandrakar
chinu007 is on a distinguished road
Hello Flappy,
Did you solve this problem by
1) multiplying the reaction rate with weight of catalyst divided by catalyst bed volume?
2) multiplying with catalyst density?
chinu007 is offline   Reply With Quote
froment, steam reforming, udf
udf for superheated steam? stefan pauly FLUENT 5 September 17, 2014 15:22
Steam reforming in SOFC module anchoryan FLUENT 0 December 15, 2010 05:09
methane steam reforming reaction rate... yerem3 FLUENT 0 August 30, 2010 09:43
Steam reforming with FLUENT? Claud FLUENT 22 May 17, 2010 16:54
Modelling steam-dry reforming of methane in FLUENT 6.2. Talliks FLUENT 0 March 2, 2010 06:55
