UDf current density integration
Old   October 23, 2019, 09:41
Default UDf current density integration
Domagoj
Domagoj is on a distinguished road
i need to integrate current density in my axisymmetric Fluent model in order to obtain self-induced azimuthal magnetic field (Ampere circuital law) - see attached picture.
Z is symmetry axis, r is radial distance.
How to write UDF for this problem?
Is it possible to loop cells for various z=const from r=0 to the right boundary while replacing integral with sum of finite values calculated in cell center?
Any suggestions?
Thanks.
Domagoj is offline   Reply With Quote
Old   October 23, 2019, 21:25
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
there is build in electric potential model in fluent
did you try to use it?
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   October 24, 2019, 01:38
Domagoj
Current density values are obtained using electric potential model, but it does not solve magnetic field values.
Also, there is advanced add-on module called MHD but it solves problems with externally-imposed magnetic field. In my case magnetic field is self-induced and I do not see how to apply it?
My final goal is to obtain Lorentz force from current density and magnetic field and use it as momentum source. Than I could solve fluid stirring problem.
Old   October 25, 2019, 00:07
Alexander
I'm not sure how to do it step by step.
But it seems you should use user-defined scalar to define your magnetic field
read Ansys Fluent Customization manual for more information regarding UDS
best regards
Old   October 25, 2019, 00:10
Alexander
does current field pre-defined? or you should solve some equation to get current distribution?
best regards
Old   October 25, 2019, 01:26
Domagoj
Current field is solved using Electric potential model with appropriate boundary conditions at the external walls. I have saved all necessary cell data in UDM's and should solve Ampere equation to obtain azimuthal magnetic field.
It should be relatively simple numerical integration but I am not sure how to locate and loop cells from some constant z-coordinate (and r=0) to the right boundary end perform summation instead of integral.
Old   October 25, 2019, 02:24
Alexander
inside cell loop you may check if the cell is inside region (z-> your_boundary_coord) and make summation if True.
using C_CENTROID macro you can get coordinate of cell
detail information in Ansys Customization Manual
best regards
Old   October 25, 2019, 05:45
Domagoj
Thanks, I will try to write some code and post it here.
I thought that someone already has something similar that could be modified for my case.
Old   August 25, 2022, 17:52
Rodrigo Villarreal
rodrigovime is on a distinguished road
I have the very same problem but in ANSYS CFX. It seems that I cannot integrate using the NLOC array. Is there a way to perform numerical integration using User Fortran?
rodrigovime is offline   Reply With Quote
Old   September 30, 2022, 07:22
Domagoj
In the end I obtained Lorentz force using magnetic vector potential method.
I can't remember the implementation details (UDS were used), it was long time ago, but read this paper carefully.
https://iopscience.iop.org/article/1...-3727/37/6/013
UDF for modifying density of mixture phase during the calculating process sola86 Fluent UDF and Scheme Programming 2 May 28, 2019 09:24
Density UDF Divergence Baden Fluent UDF and Scheme Programming 0 January 11, 2017 15:25
Interpret-Real Gas UDF ndabir Fluent UDF and Scheme Programming 3 November 18, 2015 07:29
How to get the current density using TUI in Fluent PEMFC module? Prince Abraham FLUENT 1 November 2, 2015 11:57
Warning 097- AB Siemens 6 November 15, 2004 04:41
