UDF to define the vector transport equation
Old   August 31, 2012, 05:47
Default UDF to define the vector transport equation
Vaze
mvee is on a distinguished road
Hi
Through the UDS, scalar transport equation can be defined. I would like to define the vector transport equation. How can i define it?
regards
Mvee
mvee is offline   Reply With Quote
Old   August 31, 2012, 08:14
Amir's Avatar
Amir
Amir is on a distinguished road
You would need 3 UDSs as each component!
Bests,
Amir
Amir is offline   Reply With Quote
Old   September 3, 2012, 00:03
Vaze
Hi Amir
Can you describe how and which UDS to use?
Mvee
Old   September 3, 2012, 03:38
Amir's Avatar
Amir
Originally Posted by mvee View Post
Hi Amir
Mvee
Suppose you wanna model momentum equation via UDS. You have to define 3 UDSs; u, v and w; and provide appropriate transport terms such as convection, diffusion, unsteady and source terms for each of them. A UDS has a general form of transport equation which you can modify for your purpose.
Bests,
Amir
Old   September 3, 2012, 04:07
Vaze
Hi Amir
Problem: Welding arc simulation
Description:
1) No. of zones: 3
2) Solid zone: electrode and workpiece (copper)
3) Fluid: argon (electrically conductive)
Current is imposed on the electrode which passes from the fluid and workpiece (which is at zero potential). Due to the current electro-magnetic field is generated which is governed by Maxwell’s equation (consists of current continuity and potential vector equation). These equations are having same form as that of our NS equations.
I have defined one UDS for voltage to solve current continuity equation. In the similar form do you mean to define UDS for vector A. Can you describe how shall I follow for the physics mentioned above? Also the output of this UDS will go as source term in momentum equation.
Thanks
Mvee
Old   September 3, 2012, 05:29
Amir's Avatar
Amir
Ok, you'll also need a vector transport equation. You can consider a vector transport equation as 3 scalar transport equation (one for each component) and model each of them via a UDS. Here you have a vector A, so define 3 UDS as Ax, Ay and Az as its components. So consider your vector equation and decompose it into 3 scalar equation. Finally with simple UDFs you can add each component of your added equations into each momentum components without any trouble.
Bests,
Amir
Old   September 3, 2012, 06:13
Vaze
Hi Amir
Thank you very much for your help, still have some doubt.
My algorithm will work in following manner -
(1) Current continuit equation: \Delta\Phi=0 /*\Phi = applied voltage and \Delta = Laplacian operator*/
(2) current density, j = -\sigma\nabla\Phi
(3) Potential vector equation: \Delta\vec{A}=\mu\vec{j}
First and third point can be applied through UDS. How to interface (required to solve point 2) between point 1 and 3? Is it required UDF?
Old   September 3, 2012, 07:34
Amir's Avatar
Amir
Dear friend,
It depends. It doesn't need to evaluate j explicitly if you just want to obtain A! you can substitute j from equation 2 into 3 directly and remove the j variable. But if you want to obtain j as well; yes, you'll need a UDF to store the phi gradient into a UDM. It should be noted that you would also need UDFs for defining source terms of equation 3.
Bests,
Amir
Old   September 10, 2012, 01:27
Vaze
Hi Amir
Thank you very much for your kind co-operation. I have solved these equations.
Thank you
Mvee
Old   October 30, 2022, 15:08
Smile
mahdi abdollahzadeh
mm.abdollahzadeh is on a distinguished road
Originally Posted by Amir View Post
Dear friend,
Bests,
Hi amir, If you had any success with the plasma torch model can you share a case here?
I have developed a code for that but I am facing problem with converging temperature.
mm.abdollahzadeh is offline   Reply With Quote
How to write equation into UDF? Jane Fluent UDF and Scheme Programming 10 August 30, 2023 04:53
Swtich on or of the resolution of an equation in UDF pifou74 FLUENT 0 September 29, 2009 16:02
UDF: exporting a variable between two DEFINE function Carlo FLUENT 3 August 19, 2009 12:21
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
UDF to add two governing equation?? T.K. Yang FLUENT 0 May 9, 2006 02:54
