"cx-interrupt" not Interrupting
Like Tree3Likes
  • 1 Post By Baden
  • 1 Post By pakk
  • 1 Post By pakk
Old   February 11, 2017, 14:53
Default "cx-interrupt" not Interrupting
Baden is on a distinguished road
Hello all.
I have defined a SCHEME variable using the following TUI command:
(rp-var-define 'interrupt/flag 0 'interger #f)
Initially, the variable "interrupt/flag" has a value of 0, but this value is changed to 1 via UDF based on a certain condition. I want the simulation to stop once the variable is changed to 1, so I implemented the following in Solve - Execute Command panels:
However, when the value of ""interrupt/flag" is changed to 1, the following text appears in the console but the simulation continues without stopping.
Does anyone have any idea why the simulation is not properly being interrupted? There is remarkably little documentation on the SCHEME language and even less on cx-interrupt.
kele likes this.
Baden is offline   Reply With Quote
Old   February 13, 2017, 04:28
pakk will become famous soon enough
I think you made a typo in your scheme command, it should be integer and not interger.
On the question you asked: I have no idea, but I am interested in this way of working, it looks useful if it works. Do you get the same behavior when you manually press control-C?
I see the command (cx-interrupt-client) also exists, maybe this could be what you need?
Baden likes this.
pakk is offline   Reply With Quote
Old   February 13, 2017, 20:38
The typo was not present when in the SCHEME command I used, but thank you for pointing that out.
Pressing control-C results in the same problem: the simulation says "Interrupting" but does not stop. However, pressing control-C twice properly stops the simulation. I also tried the "cx-interrupt-client" command, but it appeared to have no effect (the "Interrupting" text did not appear in the command window).
Old   February 14, 2017, 02:45
If control-C twice works, did you try to put (cx-interrupt) twice?
(if (> (rpgetvar 'interrupt/flag) 0) (begin (cx-interrupt) (cx-interrupt)))
Baden likes this.
Old   February 15, 2017, 22:25
I tried both of the following neither worked.
(if (> (rpgetvar 'interrupt/flag) 0) (begin (cx-interrupt) (cx-interrupt-client)))
Pressing control-C twice gives the following message which I was unable to replicate with the latter of the two codes posted above.
Old   February 16, 2017, 03:42
Kevin
KevinZ09 is on a distinguished road
I've got little to no experience using the SCHEME language, but to me it almost seems like you need to interrupt twice because the first time it interrupts the iteration loop within the current time step and the second time it interrupts the time step loop. So perhaps there are different commands for that.
Did you consult the following website to get more information:
http://www.scheme.com/tspl4/
KevinZ09 is offline   Reply With Quote
Old   February 16, 2017, 11:18
It looks like it should be some combination of (cx-interrupt) and (cx-interrupt-client). I tried a little bit, and with (cx-interrupt) I get the same response, but with (cx-interrupt-client) I get "()" instead of "Interrupting client...". I tried to add parameters, as in (cx-interrupt-client 0), (cx-interrupt-client 'test), but the response was the same every time.
My conclusion: I don't know how to do this, and don't know how to find out.
Old   February 16, 2017, 15:06
I have encountered the same issue. Unless anyone on the forums knows any better, I believe this is a dead end.
Old   February 17, 2017, 03:53
If you can go to Fluent support, it might not be a dead end.
Old   February 27, 2017, 21:27
Unfortunately, this avenue is not available to me as a student user.
Old   September 12, 2022, 08:14
Odisha
Siba11 is on a distinguished road
I wrote this command in the 'Execute Command' dialog box to stop a transient simulation. (I initially took the value of 'interrupt/flag' as 5).
(if(>(rpgetvar 'interrupt/flag) 0) (set! mstop? #t))
Apparently, it's working, and the solution stops as soon as the condition is violated. I found this on youtube. But I don't have any further information about this command.
Also, if possible, could you guide me on the UDF part. I'm encountering some problem with the DEFINE_ADJUST UDF I wrote.
Siba11 is offline   Reply With Quote
Old   September 13, 2022, 02:02
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
I believe that instead of
rpgetvar
should be
%rpgetvar
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   October 12, 2023, 09:49
kele is on a distinguished road
[QUOTE=Siba11;835714]Hi,
Hey friend, have you solved this problem yet? Currently, I am experiencing this issue. I am looking for help to solve the problem, here is my code. Run the code but FLUENT does not stop running.
[CODE](rp-var-define 'interrupt/flag 0 'integer #f)
(define (interrupt)
(if (> (%rpgetvar 'interrupt/flag) 0)
(cx-interrupt)))
kele is offline   Reply With Quote
cx-interrupt, scheme
Interrupting calculation at value aalansari FLUENT 0 August 22, 2014 08:03
Interrupting a run in progress austin.m SU2 4 October 4, 2013 09:55
Interrupting a Journal File svp FLUENT 2 February 16, 2011 08:00
Interrupting Gambit w/o leaving CPU busy? Chris Bailey FLUENT 0 January 26, 2005 16:29
