Error running UDF for water evaporation-condensation problem |
July 5, 2023, 23:28 |
Mat
Rep Power: 9 |
I am encountering an error while trying to run a UDF in ANSYS Fluent for a water evaporation-condensation problem. The purpose of the UDF is to calculate the saturation pressure. In my simulation, phase 1 represents water in the liquid state, while the other phase represents a mixture of air and water vapor.
I have successfully compiled the UDF code without any errors or warnings. Additionally, I have assigned the saturation temperature in the "Saturation" tab within the "Evaporation-Condensation" settings. However, when I attempt to perform the initialization step, I encounter the following error: -------------------------------------------------------------------------------------- Node 0: Process 28764: Received signal SIGSEGV. The fl process could not be started. -------------------------------------------------------------------------------------- Based on my understanding of the problem, I believe that the error might be occurring within the "mixture_species_loop" of my UDF. Interestingly, everything seems to work fine before this part. I would greatly appreciate any insights or suggestions regarding the possible reasons behind this error. -------------------------------------------------------------------------------------- #include "udf.h" #define MOLAR_MASS_WATER 18.01534 /* g/mol*/ #define MOLAR_MASS_AIR 28.97 /* g/mol*/ #define RHO_WV 0.5542 /* kg/m3*/ #define RHO_AIR 1.225 /* kg/m3*/ DEFINE_PROPERTY(saturation_temp,c,t) /* t: mixture thread, c: cell variable, Cell volume*/ { real vol = C_VOLUME(c, t); Thread *pt = THREAD_SUB_THREAD(t, 0); /* Primary phase thread-water*/ Thread *st = THREAD_SUB_THREAD(t, 1); /* Secondary phase thread-air-vapour mixture template*/ real vf_s = C_VOF(c, st); /* Get the volume fraction of secondary phases*/ real vf_p = 1 - vf_s; /* Get the volume fraction of primary phases*/ real p_mix = C_P(c, t); /* Get the pressure of the mixture */ real p_op = RP_Get_Real("operating-pressure"); /* Get the operating pressure*/ real rho_p = C_R(c, pt); /* Primary phase density*/ /* Get mass fractions in primary phase*/ real mf[2]; /*to store mass fractions*/ Material *m = THREAD_MATERIAL(pt); Material *sp = NULL; int i; /* Species index - 0 for water vapor and 1 for air+vapour*/ mixture_species_loop(m, sp, i) { mf[i] = C_YI(c, pt, i); } real p_w; /* Water vapor pressure for the cell*/ if (vf_s == 1) /* If secondary phase only*/ { p_w = p_mix + p_op; } else /* If primary phase or mixture of phases*/ { /* Find the partial pressure of water vapour, partial pressure = cell pressure * water mole fraction*/ real m_prim = rho_p * vol * vf_p; /* mass of primary phase in cell*/ real m_wv = mf[0] * m_prim; /* mass of water vapour in cell*/ real m_air = m_prim - m_wv; /* mass of air in cell*/ real N_wv = m_wv / MOLAR_MASS_WATER; /* No of moles in water vapour*/ real N_air = m_air / MOLAR_MASS_AIR; /* No of moles in air*/ real N_total = N_wv + N_air; /* total moles*/ p_w = (C_P(c, t)+ p_op)* (N_wv / N_total); /* water vapour partial pressure*/ } real t_sat; t_sat = (1730.63 / (10.196 - log10(p_w))) + 39.724; /* Calculate saturation temperature*/ return t_sat; } -------------------------------------------------------------------------------------- |
evaporation condensation, mixture model., multiphase, saturation temeprature |
Mixture Model with Condensation and Evaporation on Vertical Wall | gartz89 | FLUENT | 3 | March 20, 2020 09:16 |
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 04:37 |
Problem condensation/ evaporation (condensate water vapor) | bigfoot47 | FLUENT | 0 | October 21, 2019 08:07 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
parallel UDF problem | kerem | FLUENT | 2 | June 20, 2006 06:56 |
