July 27, 2023, 04:36 |
Udmi
HRSD
Rep Power: 2 |
Hi Dears,
i wrote a UDF which can see in below, in this UDF, after calculating, UDMI value not saved and is zero. please help me for solving this problem. thank. begin_c_loop(c,t) { inst_tabs = C_T(c,t); inst_rdot = aprexp * exp((-acte) / (ugc * inst_tabs)); inst_mdot = frho * burn_area * inst_rdot; C_PROFILE(c,t,i) = inst_mdot; sum_inst_tabs += inst_tabs; C_UDMI(c,t,0) = inst_rdot; } end_c_loop(c,t) |
July 28, 2023, 00:20 |
Alexander
Rep Power: 34 |
if each variable here is defined well no problems should exist
best regards ****************************** press LIKE if this message was helpful |
July 28, 2023, 07:37 |
Udmi
#3 | |
HRSD
Rep Power: 2 |
thank you. |
July 28, 2023, 09:54 |
Odisha
Rep Power: 6 |
You have to allocate a memory location inside ansys fluent before you can call C_UDMI macro. See if this helps.
July 28, 2023, 12:41 |
HRSD
Rep Power: 2 |
UDMI and DEFINE_EXECUTE_AT_END | MsRuby | Fluent UDF and Scheme Programming | 2 | July 2, 2018 02:43 |
Running out of UDMI, what can in use to replace it ? | Sdvk | Fluent UDF and Scheme Programming | 0 | May 23, 2014 13:16 |
problems with UDMI... !!! | Nady | FLUENT | 0 | May 16, 2007 02:38 |
Problem with Dissipation rate storage in UDMI | Sam | FLUENT | 0 | January 26, 2006 05:19 |
UDMI error when memorizing Dissipation of TKE | Lohen | FLUENT | 0 | June 23, 2005 09:59 |
