Turbulent viscosity for transitional SST model in ANSYS Fluent |
Bovinille
Rep Power: 0 ![]() |
Hello all,
How can one access the turbulent viscosity for transitional SST model in a UDF for further calculations? This is needed in my investigation to estimate the turbulent diffusivity for later solving a specie transport equation. Although the turbulent viscosity is visible in the GUI, I have tried the macro C_MU_T(c,t) in a User Define Memory (UDM) but it doesn’t work as seen the attached picture. It seems this macro only works for the k-e and k-w models. I tried storing in UDMs other variables such as turbulent kinetic energy (with C_K(c,t)), specific dissipation rate (with C_O(c,t)) and strain rate magnitude (with C_STRAIN_RATE_MAG(c,t)), to calculate it according to Menter’s work. However, only the latter macro works as the others (i.e., C_O(c,t) and C_STRAIN_RATE_MAG(c,t)) didn’t work. Also, I can create a custom field function for turbulent viscosity in the GUI but how does one access this within a UDF? Is there way to pass custom field functions into UDM for UDF calculations? Thanks, and I look forward to hearing from you. |
How to Implement an Algebraic Turbulent Heat Flux Model in FLUENT | George_J | FLUENT | 0 | May 12, 2022 03:39 |
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 16, 2020 23:44 |
Viscosity ratio in gamma-theta transition model based on k-w sst turb model | Qiaol618 | Main CFD Forum | 8 | June 9, 2012 06:43 |
What different SST turbulent model between Fluent 12.1 and Fluent 6.3 | opehterinar81 | FLUENT | 0 | August 24, 2011 06:34 |
how can export model from fluent to ansys | abcd19 | ANSYS | 0 | June 18, 2011 15:15 |
