Temperature and flux continuity across interphase.
Old   December 4, 2021, 12:11
Default Temperature and flux continuity across interphase.
anonymous
ss_stardust is on a distinguished road
Hi all,
I am working on non equilibrium thermal model in Ansys Fluent. It has fluid as well solid porous zones superimposed over each other. Both the zones are adjacent to a solid wall which is subjected to a heat flux boundary condition.
I have created a non-conformal mesh and manually created an interface between wall, porous solid and porous fluid walls. The flux continuity has been maintained by fluent by I want the temperature at the interface for each of the boundaries to be the same too. How can I achieve this?
Thanks in advance.
ss_stardust is offline   Reply With Quote
Old   October 12, 2023, 04:23
Mohammad Sameer
Selawe is on a distinguished road
Originally Posted by ss_stardust View Post
Hi all,
Thanks in advance.
Hello dear
did you figure it out? if yes can you please help.
Thanks.
Selawe is offline   Reply With Quote
conjugate heat transfer, fluent - udf, interface bc
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
Radiation interface hinca CFX 15 January 26, 2014 17:11
build my own multi-region solver : pb with flux continuity Cyp OpenFOAM Programming & Development 2 November 27, 2013 12:19
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
