DPM: UDF - loop over all particles
Like Tree7Likes
Old   February 1, 2007, 04:54
Default DPM: UDF - loop over all particles
chris
I would like to have my EXECUTE_AT_END udf loop over all particles in the domain. I would like to know how many particles there are in every cell. But i get a "Segmentation violation" when i want to access any variable that is beeing processed during the "begin_particle_cell_loop". I am using FLUENT 6.3
Thanks for your help!
This is my code:
DEFINE_EXECUTE_AT_END(execute_at_end) {
Thread *t;
Domain *d;
Particle *pi; /* Particle index for looping over all particles in the cell */
real numb_cell=0.;
real numb_part_dom=0.;
cell_t c;
d = Get_Domain(1); /* mixture domain if multiphase */
thread_loop_c(t,d)
begin_c_loop(c,t)
numb_cell += 1;
begin_particle_cell_loop(pi,c,t)
numb_part_dom += 1;
end_particle_cell_loop(pi,c,t)
end_c_loop(c,t)
printf("Number of cells %g\n", numb_cell);
printf("Number of particles %g\n", numb_part_dom);
fflush(stdout); }
Old   July 11, 2009, 08:38
Default any solution?
Mayank Kumar
kmayank is on a distinguished road
Hey Chris,
Did you manage to get any solution to this problem? I am also stuck there.
Thanks
Mayank
kmayank is offline   Reply With Quote
Old   November 10, 2010, 23:20
john
johnwinter is on a distinguished road
Hi Kmayank,
Do you have any idea How to get particle concentration in each cell?.
I am facing that problem now. any suggestion
John
johnwinter is offline   Reply With Quote
Old   November 18, 2010, 15:39
Rok Sibanc
snow is on a distinguished road
DEFINE_ON_DEMAND(particle_cells_count)
Domain *d;
Thread *t;
cell_t c;
Particle *p;
int particles;
int cells;
d = Get_Domain(1);
Alloc_Storage_Vars(d, SV_DPM_PARTICLE_BIN, SV_NULL);
bin_particles_in_cells(d);
particles=0;
cells=0;
thread_loop_c(t,d)
begin_c_loop(c,t)
cells++;
begin_particle_cell_loop(p,c,t)
particles++;
end_particle_cell_loop(p,c,t)
end_c_loop(c,t)
Free_Storage_Vars(d, SV_DPM_PARTICLE_BIN, SV_NULL);
Message("Number of cells: %d\n",cells);
Message("Number of particles: %d\n",particles);
snow is offline   Reply With Quote
Old   December 1, 2010, 16:22
Roman Gobitz-Pfeifer
Wikie is on a distinguished road
hi,
are you able to compile the last code? I'm always getting the following error message:
error C2198: 'bin_particles_in_cells' : too few arguments for call
The error occurs in this line:
Any idea why I'm not able to compile this code??
cheers
wikie
Wikie is offline   Reply With Quote
Old   January 18, 2011, 01:38
I still stuck at this problem. I'm always getting the same error message saying: "error C2198: 'bin_particles_in_cells' : too few arguments for call".
Can anybody help me please, I have to know the number of particles to continue my work.
Thanks,
wikie
Old   January 18, 2011, 04:08
Max
coglione is on a distinguished road
I would do it the following way:
loop(I, Ilist)
loop(p, I->p)
c = P_CELL(p);
c_t = P_CELL_THREAD(p);
parcel_trapped+=1;
num_part=p->number_in_parcel;
cheers
cdf_user, wc34071209 and Narita like this.
coglione is offline   Reply With Quote
Old   January 19, 2011, 13:24
Hi coglione,
thank you very much for your reply.
I wrote the UDF as you recommended, but I want to make sure that I understood erverything.
In my case I'm getting num_part = 12, parcel_trapped = 45 and number_in_parcel = 0. parcel_trapped is clear, this is the number parcel from my surface injection. But why is number_in_parcel = 0? This should be the number of particles in one parcel, isn't it? Do I have to multiple num_part x parcel_trapped to get the total number of particles in my domain??
thank you
Wikie
Here you can see my UDF.
#include "udf.h"
Injection *Ilist;
Injection *I;
Particle *p;
cell_t c;
Thread *c_t;
int parcel_trapped = 0;
int num_part = 0;
int number_in_parcel = 0;
Ilist = Get_dpm_injections();
loop(I, Ilist)
loop(p, I->p)
c = P_CELL(p);
parcel_trapped+=1;
Message("num_part: %d\n",num_part);
Message("parcel_trapped: %d\n",parcel_trapped);
Message("number_in_parcel: %d\n",number_in_parcel);
Old   January 20, 2011, 03:04
Max
1) number_in_parcel is a member function of the particle class defined somewhere in the source code of Fluent --> you redefine and initialize it with zero what may cause the behaviour you observe.
2) number_in_parcel returns a floating point number --> define num_part as real
cheers
cdf_user likes this.
Old   January 20, 2011, 11:53
Hi coglione,
sorry it's me again. I change my UDF as recommended, but now the result is num_part=0 and parcel_trapped = 0 :-(
Could you please check my UDF again?
Thank you very much,
Wikie
#include "udf.h"
Injection *Ilist;
Injection *I;
Particle *p;
cell_t c;
Thread *c_t;
real num_part = 0;
loop(I, Ilist)
loop(p, I->p)
c = P_CELL(p);
parcel_trapped+=1;
Old   January 23, 2011, 08:18
Hi coglione,
I still wasn't able to solve this problem. I looked up number_in_parcel in the dpm_types.h file and I found "real number_in_parcel; /* number of particles in parcel (unsteady only) */". I can use this just in unsteay simulation, am I right? But my simulation is steady :-( Any ideas to get the number of all particles in whole domain for stady cases?
I'm finally interested in the total reacting surface of all particles. Perhaps there is a better way to determine this area.
Greatings,
Wikie
Old   May 10, 2011, 11:15
patty
TedBrogan is on a distinguished road
coglione (or anyone else for that matter),
Where did you find the command for loop(I,Ilist) { }? Stumbling upon this thread and finding that command was a major help for the udf I'm working on. I need a few more of these undocumented commands to finish the udf, and I was wondering if you knew of a place where I could find all of these. I've tried going through files like dpm.h, but I don't see how you could know loop(I,Ilist) is a command from that.
Specifically, I'm trying to change the start and stop time of unsteady particle injection in a udf. It's easy enough and documented how to change position, velocity, etc in the udf help files, but I can't find anything on this one.
Thanks!
TedBrogan is offline   Reply With Quote
Old   May 11, 2011, 01:05
Hi TedBrogan,
this is the normal command for loops. You'll also find it in manuals. I also learned this due to my discussion here in the forum.
cheers
wikie
Old   March 20, 2012, 18:15
cdf_user is on a distinguished road
loop(I, Ilist)
loop(p, I->p)
c = P_CELL(p);
parcel_trapped+=1;
cheers
Ilist = Get_dpm_Injections();
does not work. I get the error
function: "Get_dpm_Injections" not found (pc=12).
I have included udf.h, dpm.h, surf.h, mem.h, sg_mphase.h, sg.h,
cxiface.h
Please help!
cdf_user is offline   Reply With Quote
Old   March 20, 2012, 19:06
Originally Posted by Wikie View Post
Hi coglione,
thank you
Wikie
#include "udf.h"
Injection *Ilist;
Injection *I;
Particle *p;
cell_t c;
Thread *c_t;
int num_part = 0;
loop(I, Ilist)
loop(p, I->p)
c = P_CELL(p);
parcel_trapped+=1;
My Get_dpm_Injections does not works
Fluent says function Get_dpm_Injections not found
I have included "dpm.h"
Please Help!
Old   April 21, 2012, 02:06
Thanks!
If you go in system files of the fluent, you will find many .c files in include folder. One of those files is dpm.h. All the commands are listed there.
Old   April 24, 2012, 03:00
Default CFD Simulation of Gas turbine Engine_ Combustion Chamber
  #17
juzer_700 is on a distinguished road
Hello everyone,
Can anyone suggest me a good document/book to start with simulation in gas turbine engine (combustion chamber).
I am planning to do the post processing in FLUENT. Is Openfoam software better than Fluent for combustion purpose?
Also, I intend to use C language to develop the code. Does Fluent take code written in Fortran. And which one is better? Fortran or C?
Please help me as I'm a beginner in this field.
juzer_700 is offline   Reply With Quote
Old   April 24, 2012, 05:49
Fluent is better. Fluent takes c++ code for user defined functions. I dont much about combustion so cant really recommend a book. I have experience in simulating turbomachinary though..
Old   April 24, 2012, 12:12
ADI
A. N.
ADI is on a distinguished road
Send a message via MSN to ADI
JUZER_700, OpeanFOAM is completely custom. As in you can define your own equations for everything from Continuity to Turbulence and much more.
FLUENT commercial package however has a ton of these in-built and ready to use.
As for good books on gas turbine combustion chamber i suggest
GAS Turbine Combustion by Lefebvre, Mechanics and thermodynamics of Propulsion by Hill and petersen and the AIAA series book named Aerothermodynamicsof gas turbine and rocket propulsion by Oates...
Adi.
ADI is offline   Reply With Quote
Old   April 25, 2012, 01:46
@ADI Thanks for the suggestion. I am planning to code advance combustion model and then link it to fluent/openfoam. I have certain parts of the code written in Fortran. Is there anyway I can directly use the fortran code in FLUENT?
Do I need to convert all the FORTRAn code into C language? Any method?
Please help.
DPM UDF Injection leads to 2 different particles sega Fluent UDF and Scheme Programming 4 December 28, 2017 22:57
DPM - do the particles affect the liquid? Nikhil Dani FLUENT 0 January 1, 2009 11:58
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 15:57
DPM: using UDF for creating and deleting Particles Markus Alzon FLUENT 0 July 4, 2007 01:18
DPM; particle seeded / deleted by UDF Laika FLUENT 6 January 22, 2006 23:40
