UDF with fluent 6.3 and Visual S. 2008
Old   April 1, 2008, 18:23
Default UDF with fluent 6.3 and Visual S. 2008
allen
I used the Fluent 6.3.26 and Visual Studio to compile user defined functions. but I always have error massages as below. These UDF works fine with Fluent 6.2 and Visual studio2005.
c:\fluent.inc\fluent6.3.26\src\config.h(119) : error C2143: syntax error : missing '{' before ':'
c:\fluent.inc\fluent6.3.26\src\config.h(119) : error C2059: syntax error : ':'
C:\Fluent.Inc\fluent6.3.26\cortex\src\dll.h(58) : error C2061: syntax error : identifier 'CX_DLL_GetProc'
C:\Fluent.Inc\fluent6.3.26\cortex\src\dll.h(58) : error C2059: syntax error : ';'
C:\Fluent.Inc\fluent6.3.26\cortex\src\dll.h(58) : error C2059: syntax error : 'type'
does anyone have suggestion on how to fix it? many thanks
Old   April 14, 2008, 00:29
Default Re: UDF with fluent 6.3 and Visual S. 2008
PARXANG
I had the same problem once I switched to 64 bit machine. Maybe you want to run Fluent from Microsoft.net Framework SDK V2.0 (64bit) command prompt instead of the conventional VC command prompt from the start menu. I worked for me.
Good Luck
Old   April 18, 2008, 08:35
allen
Your suggestions works. thanks a lot!
Old   October 23, 2012, 04:53
dengjiajia
dunga82 is on a distinguished road
Originally Posted by PARXANG
;149968
Good Luck
sorry, Do you mean that we need to modify the VC command prompt of my computer?
Last edited by dunga82; October 23, 2012 at 07:20. Reason: There are vc++6.0 and .net framework sdk v2.0 in my computer, but I am not sure how to start fluent from sdk v2.0, not anothe
dunga82 is offline   Reply With Quote
install FLUENT on mandriva 2008 santosh Main CFD Forum 3 January 14, 2009 12:45
Call Fluent from Visual Basic 6 interface AbuKhawlah FLUENT 0 June 5, 2005 14:53
DO I NEED VISUAL C? stk FLUENT 5 February 11, 2004 15:05
export Fluent to Visual Nastran António Nery FLUENT 1 January 27, 2004 16:28
