can we initialize an array in UDF?
Old   May 8, 2007, 05:42
Default can we initialize an array in UDF?
blueberry
Dear all, I try to initialize an array (real AC[3][60]) using the following sentences in the UDF of DEFINE_EXECUTE_AT_END(): for (i=0;i<3;i++)
{for (j=0;j<60;j++)
{AC[i][j]=1.0;} } The task of this UDF is to write useful information into one file. Although this UDF can be successfully compiled, there is error information if iterate. The information is like this: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: () If I did not initialize the array AC[][], the iteration is correct and write some information into my specified file. Could somebody give me advices on it? Thanks a lot in advance!
Old   May 10, 2007, 04:48
Default Re: can we initialize an array in UDF?
blueberry
So strange! I try to compile it using compiled. Then it works.Does the array could not be initialized if using interpreted for compile?
Old   April 14, 2009, 12:00
Malachy O'Rourke
morourke is on a distinguished road
Blueberry,
I have a similar problem which has been giving me trouble. I just posted a thread on it.
What was the solution to your problem. Your second post is unclear
morourke is offline   Reply With Quote
array in UDF Kamal FLUENT 1 November 7, 2013 01:15
UDF for Species Mass Fraction Gradient *IN SPECIFIC ZONE * -- e.g. along axis of sym. ksiegs2 Fluent UDF and Scheme Programming 0 February 27, 2011 12:55
How to initialize a case file with udf? sima FLUENT 2 August 3, 2010 01:44
Initialising a 2-Dimensional Array in a UDF morourke Fluent UDF and Scheme Programming 0 April 14, 2009 11:55
UDF array problem Malachy FLUENT 0 February 10, 2009 10:41
