Dynamic mesh UDF executes twice
Old   April 24, 2009, 07:14
Default Dynamic mesh UDF executes twice
Gabor is on a distinguished road
Dear Forum Member,
I am trying to compute the flow around a rotating body inside a duct and having the following problem:
when I use smoothing and remeshing together my UDF that contains the dynamics of the rotating body is being executed twice, at least the DEFINE_CG_MOTION() function since my Message() output in it shows up twice. Therefore the angle of rotation is computed twice as well so Fluent thinks the body reached the desired angle of rotation (e.g. the position where the spring is unstressed) however it is just halfways. If I only use smoothing the problem does not occur however I need remeshing in order to avoid skewed cells.
The dynamics of the rotating body is just a simple equation of motion with torsional spring and viscous damping.
I am wondering if You have faced the problem already and could help me out with any suggestion.
Thanks in advance, regards
Gabor
Gabor is offline   Reply With Quote
remeshing, smoothig, udf
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Dynamic mesh UDF problem Peter FLUENT 2 November 12, 2007 02:10
writing a dynamic mesh udf ALPER ALBAYRAQ FLUENT 0 October 24, 2005 08:41
Problem related with UDF for dynamic mesh Ryan FLUENT 6 April 29, 2004 09:29
UDF problem for dynamic mesh??? lyf FLUENT 1 April 19, 2004 06:43
