July 26, 2009, 05:06 |
Convergence UDF
Jorge Muņoz
Hi!!!
I had another question...Convergence in my simulation case is obtained when Cm (moment coefficient) is uniformed. I wanted to do somehow a program to check the difference of Cm value in the last X iterations and see if it changed a lot or not in order to see convergence... Shall I do it via UDF?? or is there any other way?? In case UDF is the answer, does anybody have idea of how to do it?? Do u know of any place where to have a look to know it better?? Thanks in advance! Jorge. |
January 4, 2011, 02:17 |
osman
hi Jorge !!!
do you have any progress with your problem? How did you solve it? I have also similar problem to check the convergence during iteration with the ca, cd or cm values. guba... |
January 4, 2011, 08:04 |
Jorge Muņoz
Hi gubarrani,
the only thing i can tell u is use monitors to check convergence. Not only residuals but also Cd values can be plotted and shown in Fluent. Moreover, you can get a .txt file where these values are written, helping you for checking it! Regards, L3munoz. |
Dynamic Mesh UDF | Qureshi | FLUENT | 7 | March 23, 2017 07:37 |
How to add a UDF to a compiled UDF library | kim | FLUENT | 3 | October 26, 2011 21:38 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
UDF...UDF...UDF...UDF | Luc SEMINEL | FLUENT | 0 | November 25, 2002 04:03 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 04:01 |
