August 12, 2017, 14:09 |
#41 |
flanag
Rep Power: 8 |
Hi Samcfd,
I am doing something similar i have applied the udf to the airfoil with a 20deg pitching amplitude and set the fluid as deforming but i keep getting negative volume detected and i have changed some of the settings but problem persists, did you eventually sort out the problem you were having? |
September 14, 2017, 08:23 |
#42 | |
leo
Rep Power: 8 |
hi, dear cheaklapomme.
maby your udf work now? i want to do the same case of that,and i have the same code of you ,could you give me any guide.thanks a lot. Quote:
February 15, 2021, 04:12 |
Help
#43 | |
Mohammed
Rep Power: 7 |
I am looking to find a solution to my problem. So I found your response to some student and I hope to help me. I want to simulate an elbow artery by using dynamic mesh. I need to apply eq Ra(t)=0.4+20sin 7.89*t That can apply it on the wall and it will expand and converge according to the eq.. Please could you help me to write the right code as a UDF? Thank you very much Note: I have attached some file refer to the geometry and derivatives eqs Best regards |
February 20, 2021, 19:09 |
Excuse me sir.
#44 | |
sittisak
Rep Power: 5 |
I would like some advice about this problem I would like to use moving mesh or dynamic mesh with UDF for Morphing Airfoil I don't know how to use it. Please give me some advice. I'm student and leaning to this project I don't look your link on sharing would you please to sent to me at my E-mail? : agisan.r@gmail.com Sittisak. Thank you very much. Last edited by Sittisak; February 20, 2021 at 19:23. Reason: miss out some word. |
May 19, 2021, 18:10 |
#45 |
sittisak
Rep Power: 5 |
Sittisak. Thank you very much. |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Dynamic mesh UDF problem | Peter | FLUENT | 2 | November 12, 2007 02:10 |
writing a dynamic mesh udf | ALPER ALBAYRAQ | FLUENT | 0 | October 24, 2005 08:41 |
Problem related with UDF for dynamic mesh | Ryan | FLUENT | 6 | April 29, 2004 09:29 |
UDF problem for dynamic mesh??? | lyf | FLUENT | 1 | April 19, 2004 06:43 |
