How do I know wich species has which integer value?
Like Tree9Likes
  • 5 Post By gearboy
  • 2 Post By sega
  • 1 Post By Abhya
  • 1 Post By DrMaMad
Old   March 7, 2010, 06:17
Default How do I know wich species has which integer value?
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
For the usage of
C_YI(cell,thread,i)
I need to know which species hides behind the integer i!
How can I know this?
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   March 7, 2010, 10:34
sega's Avatar
Sebastian Gatzka
May this be the list from the GUI:
Materials / Mixture / Properties: Mixture Species / Edit / Selected Species ?
Is there a way to search for a specific species in this list?
Just to make sure I got the right one?
Old   March 8, 2010, 02:34
gearboy is on a distinguished road
This is an example for printing the species information on the console.
#include "udf.h"
DEFINE_ON_DEMAND(species_list)
int i = -1;
char *spe_name;
Domain *d=NULL;
Material *mix_mat=NULL;
d=Get_Domain(1);
mix_mat= mixture_material(d);
mixture_species_loop_i(mix_mat,i)
spe_name=MIXTURE_SPECIE_NAME(mix_mat,i);
Message0("species index=%d,species name=%s\n",i,spe_name);
gearboy is offline   Reply With Quote
Old   March 8, 2010, 06:09
sega's Avatar
Sebastian Gatzka
#include "udf.h"
int i = -1;
char *spe_name;
Domain *d=NULL;
d=Get_Domain(1);
Just great!
Thank you!
Old   March 8, 2010, 08:25
Default how i can open the gambit file in fluent please tell me the saving file name ,
sunny rajpal
chemicalsunnyraj is an unknown quantity at this point
i have 6.3 fluent edison
chemicalsunnyraj is offline   Reply With Quote
Old   March 8, 2010, 08:30
sega's Avatar
Sebastian Gatzka
How is this related to the topic?
Old   October 9, 2010, 16:58
Roman Gobitz-Pfeifer
Wikie is on a distinguished road
I also have to know the numbers for the species, but I don't know how to run this code :-( Can anybody explain how I get this information out of this code? I also tried to copy the code and paste it into the console. I also tried to compile this code, but I don't know how to start it.
cheers
wikie
#include "udf.h"
int i = -1;
char *spe_name;
Domain *d=NULL;
d=Get_Domain(1);
Wikie is offline   Reply With Quote
Old   October 10, 2010, 09:01
sega's Avatar
Sebastian Gatzka
Originally Posted by Wikie View Post
cheers
wikie
1. Read the manuel about UDF.
2. Save the code as *.c file.
3. In FLUENT go to menu: Define > User-Defined > Functions > Compiled ...
4. Add the c-File (Source File)
5. Click Load
6. FLUENT menu: Define > User-Defined > Execute on demand
7. Choose the function
8. Output appears. Done!
m.beh and chaitanyaarige like this.
Old   October 10, 2010, 09:20
Hi Sega,
thanks a lot. I've already done nr. 1-5, but didn't know how to execute this file. Now it's working fine.
Thanks
wikie
Old   April 15, 2013, 10:50
Question
Abhya is on a distinguished road
cheers
wikie
Wow!
thanks a lot That was so helpful to me! saved so much of my time!
Btw fluent manual (12.0 version) doesn't list anything about this macros right?? Plz correct me if i'm wrong!
where u got the info on using these macros????
chaitanyaarige likes this.
Abhya is offline   Reply With Quote
Old   April 15, 2013, 10:59
Hey I found another simple way to access the species index using macro - SV_SpeciesIndex("species_name")
species_name should exactly be the name we see in the Models-> Species transport panel!
Refer the following code for example :
#include "udf.h"
DEFINE_ON_DEMAND(M_species_list)
int i;
i = SV_SpeciesIndex("h2o");
Message("species index=%d,species name=h2o\n",i);
Old   April 17, 2013, 04:40
Great job!
#include "udf.h"
int i;
Old   September 11, 2017, 08:32
Hirakjyoti Barman
Hirakjyoti is on a distinguished road
Great job!
After loading in fluent it is showing
M_species_list:
0 .local.varargs
0 .local.end
0 save
.local.int i (r1)
1 push.int 0
3 save
4 push.string [5] Licl
7 call SV_SpeciesIndex (-1)
9 sto.int i (r1)
11 pop.int
12 save
13 push.string [36] species index=%d,species name=Licl
20 ld.int i (r1)
22 call CX_Message (-1)
24 pop.int
25 restore
26 ret.v
How can i know wht is the i for licl. plz hlp
Hirakjyoti is offline   Reply With Quote
Old   May 19, 2020, 13:25
Vidushi
Vidushi is on a distinguished road
#include "udf.h"
int i = -1;
char *spe_name;
Domain *d=NULL;
d=Get_Domain(1);
I executed the code, it gets compiled, and then it does not print anything for me Can anybody guess what might be the problem?
Vidushi is offline   Reply With Quote
Old   May 20, 2020, 00:34
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
how did you run the code?
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   May 20, 2024, 11:13
Thumbs up
  #16
Mohammad
DrMaMad is on a distinguished road
#include "udf.h"
int i = -1;
char *spe_name;
Domain *d=NULL;
d=Get_Domain(1);
so informative
amilachandra likes this.
DrMaMad is offline   Reply With Quote
How to specify surface flux of a species? ked FLUENT 18 February 15, 2022 15:03
Modelling Biomass Combustion via Species Transport Racheal FLUENT 39 January 8, 2022 07:42
PB: Saving mass fraction of species on two points with an udf biget.a FLUENT 2 July 23, 2009 03:06
Species order fluent Raddi FLUENT 1 March 13, 2009 00:21
mass fraction of species Ahmed FLUENT 0 April 18, 2007 11:57
