How do I know wich species has which integer value? |
March 7, 2010, 06:17 |
Sebastian Gatzka
Rep Power: 20 |
For the usage of
C_YI(cell,thread,i) How can I know this?
Schrödingers wife: "What did you do to the cat? It's half dead!" |
March 7, 2010, 10:34 |
Sebastian Gatzka
Rep Power: 20 |
May this be the list from the GUI:
Materials / Mixture / Properties: Mixture Species / Edit / Selected Species ? Is there a way to search for a specific species in this list? Just to make sure I got the right one?
March 8, 2010, 02:34 |
#3 | |
#include "udf.h" DEFINE_ON_DEMAND(species_list) { int i = -1; char *spe_name; Domain *d=NULL; Material *mix_mat=NULL; d=Get_Domain(1); mix_mat= mixture_material(d); mixture_species_loop_i(mix_mat,i) { spe_name=MIXTURE_SPECIE_NAME(mix_mat,i); Message0("species index=%d,species name=%s\n",i,spe_name); } } |
March 8, 2010, 06:09 |
#4 | |
Sebastian Gatzka
Rep Power: 20 |
Thank you!
October 9, 2010, 16:58 |
#5 | |
Roman Gobitz-Pfeifer
I also have to know the numbers for the species, but I don't know how to run this code :-( Can anybody explain how I get this information out of this code? I also tried to copy the code and paste it into the console. I also tried to compile this code, but I don't know how to start it. cheers wikie Quote:
October 10, 2010, 09:01 |
#6 | |
Sebastian Gatzka
Rep Power: 20 |
2. Save the code as *.c file. 3. In FLUENT go to menu: Define > User-Defined > Functions > Compiled ... 4. Add the c-File (Source File) 5. Click Load 6. FLUENT menu: Define > User-Defined > Execute on demand 7. Choose the function 8. Output appears. Done!
October 10, 2010, 09:20 |
Hi Sega,
thanks a lot. I've already done nr. 1-5, but didn't know how to execute this file. Now it's working fine. Thanks wikie |
April 15, 2013, 10:50 |
#8 | |
thanks a lot That was so helpful to me! saved so much of my time! Btw fluent manual (12.0 version) doesn't list anything about this macros right?? Plz correct me if i'm wrong! where u got the info on using these macros???? |
April 15, 2013, 10:59 |
Hey I found another simple way to access the species index using macro - SV_SpeciesIndex("species_name")
species_name should exactly be the name we see in the Models-> Species transport panel! Refer the following code for example : Code:
#include "udf.h" DEFINE_ON_DEMAND(M_species_list) { int i; i = SV_SpeciesIndex("h2o"); Message("species index=%d,species name=h2o\n",i); } |
April 17, 2013, 04:40 |
#10 | |
Great job!
September 11, 2017, 08:32 |
#11 |
Hirakjyoti Barman
Rep Power: 8 |
After loading in fluent it is showing
M_species_list: 0 .local.varargs 0 .local.end 0 save .local.int i (r1) 1 push.int 0 3 save 4 push.string [5] Licl 7 call SV_SpeciesIndex (-1) 9 sto.int i (r1) 11 pop.int 12 save 13 push.string [36] species index=%d,species name=Licl 20 ld.int i (r1) 22 call CX_Message (-1) 24 pop.int 25 restore 26 ret.v How can i know wht is the i for licl. plz hlp |
May 19, 2020, 13:25 |
#12 | |
Vidushi
Rep Power: 7 |
May 20, 2020, 00:34 |
#13 |
Alexander
Rep Power: 34 |
how did you run the code?
best regards ****************************** press LIKE if this message was helpful |
March 8, 2010, 08:25 |
how i can open the gambit file in fluent please tell me the saving file name ,
#14 |
sunny rajpal
i have 6.3 fluent edison
March 8, 2010, 08:30 |
#15 |
Sebastian Gatzka
Rep Power: 20 |
How is this related to the topic?
How to specify surface flux of a species? | ked | FLUENT | 18 | February 15, 2022 15:03 |
Modelling Biomass Combustion via Species Transport | Racheal | FLUENT | 39 | January 8, 2022 07:42 |
PB: Saving mass fraction of species on two points with an udf | biget.a | FLUENT | 2 | July 23, 2009 03:06 |
Species order fluent | Raddi | FLUENT | 1 | March 13, 2009 00:21 |
mass fraction of species | Ahmed | FLUENT | 0 | April 18, 2007 11:57 |
