May 13, 2010, 22:08 |
About P_FLOW_RATE(p)
xinyu zhao
Rep Power: 16 |
Hi world:
When i use DPM in unsteady flow, how can i get the flow rate of particles? For example, i enable the interaction with continuous phase in calculation, injecting 100 particles on inlet surface, setting the Total flow rate is 0.05kg/s in injection panel. How the fluent use the P_FLOW_RATE(p) calculation? What's result? Thanks in advance! |
