UDF execution problem
Like Tree1Likes
  • 1 Post By Philipp_Sch
Old   April 12, 2011, 12:01
Question UDF execution problem
Ján
argeus is on a distinguished road
Dear all,
I need your help. I cant find out how FLUENT executes UDFs in .c-file. A .c-file usually consist of a few UDFs marshalled in some logical order. Does FLUENT execute the UDFs in order they have been written?
I used UDF in testing geometry, and it works OK, but when I use it in another geometry (needed for real calculations), there is a problem with order of execution.
All parameters of boundary conditions of testing and real geometry are the same.
Ive made a write-bc file for both cases and the order of cruical UDFs (and boundary conditions as well) was swaped. Ive tried to change them and read bc file back, but finally, the order didnt change.. Am I able to affect it?
Thank you for any suggestion.
argeus is offline   Reply With Quote
Old   April 13, 2011, 08:08
dmalcher is on a distinguished road
I've had a similar problem with the order of execution of several UDFs. Apparently, FLUENT does not execute the UDFs in order the have been written.
Perhaps you can solve your problem using the UDF DEFINE_EXECUTE_AT_END. The code or the (void) function within this UDF is executed at the end of every iteration (for a steady solver) or time step (unsteady solver).
However, as far as I experienced you can not execute another UDF (DEFINE_...) within it.
Regards
D
dmalcher is offline   Reply With Quote
Old   April 14, 2011, 04:39
Ján
Dmalcher, firstly thank you very much for you reply. Unfortunately, I cant use EXECUTE_AT_END, because my calculation is transient and there is a need to execute all my UDFs for every iteration. Actually, I found out, that order of executing of UDFs depends on order of boundary condition in FLUENT. I can affect the order in GAMBIT by order of specifying boundary types in reversed order (the last specified boundary type takes the first place in the list and so on). Probably there are more possibilities I dont know yet.
Old   April 14, 2011, 11:03
Philipp Schapotschnikow
Philipp_Sch is on a distinguished road
The order of execution depends
1) on the UDF type. DEFINE_ADJUST are executed at the beginning of an iteration/time step; EXECUTE_AT_END - at the end of an iteration/time step.
2) on the order in which they are hooked.
AlexanderZ likes this.
Philipp_Sch is offline   Reply With Quote
Old   April 15, 2011, 14:04
Post UDF Manual link
pranab_jha's Avatar
Pranab N Jha
pranab_jha is on a distinguished road
Originally Posted by argeus View Post
Dear all,
I dont know if you have gone through this before or not. But do take a look at this link from the UDF manual. This should give you a better picture.
pranab_jha is offline   Reply With Quote
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
A problem about 'printf' and 'Message' in UDF. LICH Fluent UDF and Scheme Programming 2 May 2, 2013 02:45
what's the problem with my udf zzyan FLUENT 0 November 4, 2010 03:56
Problem with my udf july Fluent UDF and Scheme Programming 3 June 20, 2010 06:56
udf compiling problem akr FLUENT 3 August 22, 2007 07:14
