udf eror + Define property + density
Like Tree2Likes
  • 1 Post By Amir
  • 1 Post By Amir
Old   August 29, 2011, 08:54
Smile udf eror + Define property + density
rezvan
rezvan is on a distinguished road
hi,I want to assign a high density (infinity) to a region of my 2D model.
I have writen the following code;
#include "udf.h"
DEFINE_PROPERTY(cell_density, cell, thread)
real density;
real grid_y = NODE_Y(cell, threads);
real grid_x = NODE_X(cell, threads);
if ( grid_x >= 30. && grid_x <= 40. )
if ( grid_y >= 10. && grid_y <= 20. )
density =1000000000;
but I have received the following error:
line 5: macro `NODE_Y' used with too many (2) args
can anyone help me with it?
rezvan is offline   Reply With Quote
Old   August 29, 2011, 09:24
fox000002's Avatar
fox000002 is on a distinguished road
See the definition:
#define NODE_Y(v) (NODE_COORD(v)[1])
fox000002 is offline   Reply With Quote
Old   August 29, 2011, 09:36
Amir's Avatar
Amir
Amir is on a distinguished road
you wouldn't need any UDF for this case; separate desired space and set different density.
Amir
Amir is offline   Reply With Quote
Old   August 29, 2011, 10:29
Default re
rezvan
hi,thanks for ur replying,you say true,but my teacher tell me that i should solve this problem with udf,please say me what i should to do?please write all of the udf(i am in the start of the writing udf)thanks
Old   August 29, 2011, 10:45
Amir's Avatar
Amir
Dear Rezvan,
for such cases, we use cell values instead of node ones. I didn't check this UDF; check 2 rho vales:
#include "udf.h"
DEFINE_PROPERTY(my_density, c, t)
real rho;
real cr[ND_ND];
C_CENTROID(cr,c,t);
if ( cr[0] >= 30. && cr[0] <= 40. && cr[1] >= 10. && cr[1] <= 20.)
rho =1000000000;
else
rho=1.0; //check that
return rho;
Bests,
soheil_r7 likes this.
Amir
Old   August 29, 2011, 20:56
Smile rep
rezvan
hi,i am really thank you,i take a lot of ur time,exuse me,when i interpreted this udf,acure this eror:
line 1: parse error.
plz help me
Old   August 29, 2011, 20:58
rezvan
dear fox000002 ,hi,thank u a lot,i am in the start of writting udf,plz SITUATION your sentence in my udf
Old   August 30, 2011, 04:45
Amir's Avatar
Amir
plz help me
I checked that both as interpreted and compiled one and there is not any error!
maybe there is a problem in your text editor. use this attached file.
Bests,
File Type: c density.c (232 Bytes, 143 views)
Amir
Old   August 30, 2011, 06:43
Default s
rezvan
hi,thank u a lot...with ur help,my problem solved,bud if u have time ,i am glading that u answer to my other guestions :
1=this program must be .h or .c ?
2=in this udf whats the meaning and aplication of these words:
("real" and "rho" and "cr[ND_ND] and "C_CENTROID(cr,c,t)"
3=and my importand guestion is that :
why u answer to my guestions and other guestion of every peaple ?and spend alot of ur time for me & others?
Old   August 30, 2011, 08:12
Amir's Avatar
Amir
this is a main program part which includes execution macro and should be stored in .C extension; .H extension are header files which are generally consist of class definitions such as udf.h. for more info, it's better to refer to C or C++ documentations.
real-> type definition(float); it's a class
rho-> just a name; it's an object in real class
cr[ND_ND]-> self adjusting dimension array in 2D or 3D solvers; i.e., in 2D it's cr[2] and in 3D it's cr[3]
C_CENTROID(cr,c,t)-> it stores center cell coordinate of cell index c which belongs to thread t in array cr
I'll be glad if I can help others; in this forum, you can improve your CFD knowledge regardless that you ask a question or answer that. Many questions don't take much time; like yours.
Bests,
rezvan likes this.
Amir
Old   July 10, 2015, 04:30
Default property define
  #11
hassan
bazaee is on a distinguished road
hi my friends
i want define kinetic viscosity for fluent by UDFs.
but i am very weak in c programming.
this is my equation:
please help me/
thank you
bazaee is offline   Reply With Quote
define property, density, udf eror
URGENT custom property for UDF Sandilya Garimella FLUENT 0 May 19, 2008 12:35
Interpret three UDF for property Atsu FLUENT 4 April 22, 2006 15:04
UDF to change density in species transport Karthik FLUENT 6 December 8, 2004 18:19
Warning 097- AB Siemens 6 November 15, 2004 04:41
density update by UDF in non-premixed combustion IKSOO FLUENT 2 December 8, 2002 20:37
