UDF fails to model 9.81m/s^2 gravity
Old   January 24, 2012, 17:44
Default UDF fails to model 9.81m/s^2 gravity
jpo
jpo is on a distinguished road
I tried to add a z-momentum source term to model constant gravity of 9.81 m/s^2. The UDF is below.
Gravity in operating conditions panel was turned off.
Then I removed the UDF and turned gravity on in operating conditions panel and set "operating density" to 0.
The UDF failed to model 9.81m/s^2 gravity. Would anyone know why?
UDF file>>>>>>
#include "udf.h"
DEFINE_SOURCE(gravity_source,c,t,dS,eqn)
/* VAR */
double xc[ND_ND];
double gravity;
double source;
/* BEGIN */
C_CENTROID(xc,c,t);
gravity = 9.81;
source = gravity*C_R(c,t); /*rho g */
return source;
jpo is offline   Reply With Quote
Old   January 24, 2012, 18:06
Real Name :)
ComputerGuy is on a distinguished road
JPO,
First: think about posting udf-related questions in the UDF forum (http://www.cfd-online.com/Forums/fluent-udf/)
Next: how is it failing? What are the error messages?
ComputerGuy
UDF file>>>>>>
#include "udf.h"
/* VAR */
double xc[ND_ND];
double gravity;
double source;
/* BEGIN */
C_CENTROID(xc,c,t);
gravity = 9.81;
return source;
ComputerGuy is offline   Reply With Quote
Old   January 24, 2012, 18:15
jpo
ComputerGuy, Thank you for suggesting the UDF forum. I was not aware of it.
How it fails? - Residuals oscillate and do not converge... The same case without UDF (gravity is defined in the oper. conditions panel) converges well.
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
UDF for defining granular viscosity in mixture model priyanka.asp Fluent UDF and Scheme Programming 7 May 19, 2019 18:16
How to access only one phase in multiphase model by UDF wersoe Fluent UDF and Scheme Programming 1 January 4, 2017 07:11
udf: volume fraction gradient in eulerian model jwwang FLUENT 22 April 15, 2015 06:27
UDF: how to know domain number in the model? mssound FLUENT 0 May 17, 2010 15:00
