Streamline help needed! (diagram attached)
Old   April 23, 2012, 02:05
Default Streamline help needed! (diagram attached)
dom
Dominic Ow
dom is on a distinguished road
Hi all,
I am currently doing a simulation of jet fan systems in an underground parking lot. The idea is to generate a flow profile. However, this is what I got:
Uploaded with ImageShack.us
The streamline does not 'exit' the fans as predicted and they only stay within the fans themselves. Any idea why this is the case?
Many thanks in advance!
dom is offline   Reply With Quote
Old   April 23, 2012, 05:14
shaoda169 is on a distinguished road
Did you release the 'particles' from your inlet?
shaoda169 is offline   Reply With Quote
Old   April 23, 2012, 22:21
dom
Dominic Ow
No I didn't. How do I go about doing that?
Many thanks!
Old   April 23, 2012, 22:33
zbyhu is on a distinguished road
in the geometry tab you choose start from: and then your inlets
and if the streamlines are too short, you should increase limits in the limits tab
zbyhu is offline   Reply With Quote
Old   April 23, 2012, 23:35
dom
Dominic Ow
Thanks for the swift reply zbyhu, I have already selected the inlets, and that results from the diagram was what I got... Any idea where the problem might be?
Old   April 23, 2012, 23:37
It's right there in CFD-Post, when you set choose to set streamlines. On the left.
Old   April 23, 2012, 23:43
dom
Dominic Ow
I have already done that.. I selected all the inlets, and still the result was the same. Any idea what might be the problem?
Old   April 23, 2012, 23:44
Could you maybe post a higher resolution screenshot? Can't figure much from that one..
Old   April 23, 2012, 23:50
dom
Dominic Ow
Alright hang on mate, just gotta let it finish rendering (changed a few settings), see if that works..
Old   April 23, 2012, 23:56
dom
Dominic Ow
Here it is: As you can see, the streamlines don't 'exit' the fan into the environment, which is really bugging me
flow profile, fluent, jet fan, streamline, velocity
what does dense streamline mean sunflower FLUENT 0 June 8, 2011 01:48
streamline plot for multiphase problem lionlove0903 OpenFOAM Post-Processing 2 March 14, 2011 15:25
attachDetachFvMesh ignores uniformValue of attached patch (OpenFoam 1.5-dev) schmittp54 OpenFOAM Bugs 3 November 1, 2010 04:04
who can suggest references for streamline? jeff Main CFD Forum 6 September 3, 2001 01:01
Streamline diffusion Hong Main CFD Forum 0 May 18, 2000 08:10
