operating density
Old   August 27, 2012, 11:16
Default operating density
Mohsen
smhosseini is on a distinguished road
Is there anyone that can explane for me how do fluent use operating density?
what is the influence of operating density?
smhosseini is offline   Reply With Quote
Old   August 27, 2012, 19:42
misagh
misagh is on a distinguished road
hi, maybe in your case and so many others it is unused but in some especial cases it is used.e.g. to calculate the drag or lift coeff(consider a blade in wind tunnel), or boyancy force it has sever influence on results.
misagh is offline   Reply With Quote
Old   August 27, 2012, 21:13
Fangdian
fangdian is on a distinguished road
hi misagh,
If I use the VOF and solidfication and melt model, and there are two phases which are the ideal air(primary phase)and the steel (second phase).If I want to consider the boyancy force, which is the operation density, the air or the steel ?
ps: If I want to consider the buoyancy force, what is the operation temperature if the Boussinesq Model is used, the temperature of air, or the solidification temperature of the steel or the liquid temperature of the steel ?
thank you
fangdian is offline   Reply With Quote
Old   August 28, 2012, 04:03
Mohsen
Hi misagh,
Thanks for your reply. My case is multiphase & vof
Old   August 28, 2012, 06:06
misagh
dear fangdian, since the buoyancy is related to the fluid the density of air should be considered.
about the tempereture actually i am not sure,don't wanna make you confused. you'd better make a new threat.
best regards
Old   August 28, 2012, 21:39
Smile
Fangdian
best regards
dear misagh,
Thank you very much for my question. You are kind-hearted. I will make a new threat.
operating pressure and operating density phil FLUENT 5 November 7, 2017 17:02
buyoancy and operating density Zeh FLUENT 2 March 24, 2007 07:22
operating density in buoyancy driven flow Marie-Anne Main CFD Forum 2 March 24, 2006 09:52
Specified Operating Density for Compressible VOF Andrew Wick FLUENT 1 November 14, 2005 04:58
Warning 097- AB Siemens 6 November 15, 2004 04:41
