June 7, 2012, 05:21 |
Problem with updating of mesh! Help!!!
Hi guys!!!
I attached a picture of the result of a simulation using the dynamic mesh. You could see a square on the right (the dynamic mesh zone) in a flow domain that moves according to an udf. I used the Spring-Based Smoothing e Local Remeshing Methods to update the mesh but the result was a disaster...as you can see. I set the following parameters. For Spring-Based Smoothing Methods : spring constant factor = 0 boundary node relaxation = 0 convergence tolerance = 0.001 number of iterations = 25 For Local Cell Remeshing methods I used the values of mesh scale info. Could anyone suggest me any way to fix the problem with updating of mesh? Thanks in advance! |
Dynamic Mesh Problem. | Tom Clark | FLUENT | 10 | June 21, 2021 04:27 |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
