Expanding Bubble Underwater
Old   June 8, 2012, 14:22
Default Expanding Bubble Underwater
Mike
dreamchaser is on a distinguished road
Hey guys,
I'm working on a simulation where I'm trying to simulate the rapid growth of a bubble underwater.( it grows to a diameter of 1.5cm in 100ms)
The whole purpose is to see how the shockwaves generated from the bubble interact with the surrounding walls.
This bubbe expansion is taking place within a parabolic wall.
The closes thing I found to my problem was a UDF that models the swellig of a particle. I found it from the Fluent 12 UDF Manual. However, whenever I run this UDF I get the error about how my material is not defined.
I would appreciate any help or insight you can provide for my problem. I am not sure if I am approaching this problem correctly or not.
Many thanks
Error: C:\Users\sramjatan1\Desktop\EVAP_SWELLINGLAW.C: line 9: P_MATERIAL: undeclared variable
#include "udf.h"
DEFINE_DPM_LAW(Evapor_Swelling_Law, p, ci)
{ real swelling_coeff = 1.1;
/* first, call standard evaporation routine to calculate * * the mass and heat transfer */
VaporizationLaw(p);
/* compute new particle diameter and density */
P_DIAM(p) = P_INIT_DIAM(p)*(1. + (swelling_coeff - 1.)* (P_INIT_MASS(p)-P_MASS(p))/(DPM_VOLATILE_FRACTION(p)*P_INIT_MASS(p)));
P_RHO(p) = P_MASS(p) / (3.14159*P_DIAM(p)*P_DIAM(p)*P_DIAM(p)/6);
P_RHO(p) = MAX(0.1, MIN(1e5, P_RHO(p))); }
dreamchaser is offline   Reply With Quote
Old   June 9, 2012, 03:28
ghost82's Avatar
Rick
ghost82 will become famous soon enough
P-material refers to dpm injection: have you define your injection and dpm material (this one after setting injection(s))?
ghost82 is offline   Reply With Quote
Old   June 11, 2012, 14:16
Mike
ghost82,
when you say "define your injection and dpm material" is this done in the UDF or is this done on the fluent interface panel??
What would I need to add to my UDF code to properly define my injection and dpm material??
I"m sorry but I'm new to this software.
thanks so much for the help
Old   June 12, 2012, 03:32
ghost82's Avatar
Rick
Hi Mike,
you have to set injections not in udf but in fluent panels; see this link:
http://hpce.iitm.ac.in/website/Manua...htm#Injections
After setting injections you have to go to material panel, and you will see a new item added for dpm; edit it with data for your material; ex: air if your bubble contains air.
PS: remember also to hook your udf once interpreted/compiled.
http://hpce.iitm.ac.in/website/Manua...ec-use-dpm-law
Old   June 18, 2012, 11:13
Mike
ghost82,
I followed your directions and it still says
I created an injection type and edited it in the material panel also.
However, when I interpret my UDF it still says my P_Material is not defined. What model am I supposed to run this as?
I'm not sure what I"m doing wrong still.
thanks for the help
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
bubble rising in a column swamysrikanth Main CFD Forum 2 September 27, 2010 08:59
Separation bubble, hypersonic compression corner ben akih CFX 3 December 10, 2006 16:33
gas hold up in bubble Shelly Main CFD Forum 0 November 13, 2006 00:28
Query on VOF for Bubble rise Vamsi Main CFD Forum 0 December 22, 2005 00:02
