melting PCM
Old   June 19, 2012, 09:44
Default melting PCM
pespru
maherm is on a distinguished road
I’m trying to investigate the melting process of phase change material (PCM) and the enhancement of heat transfer by using metal particles. However, I try to investigate the heat transfer enhancement in the model by mixing the PCM bulk. The particle size is in the order of nano-meter, so DMP is not suitable for this problem.
So as a summery we can say that “solid PCM with nano metal particles” transfer to “liquid PCM with also nano metal particle”, and no melting of metal is happened as melting point is high for metal.
One way of doing this is to change the thermal properties (density, k and Cp) of both “solid wax” and “liquid wax” depending upon concentration of metal particles. So I was thinking if there is other way to define the physical properties of the PCM with the particles by write c-code and use user defined function (USF).
Say “volumetric” concentration of metal is v per unit volume of mixture, so Cp will be,
Cp_mixture = Cp_wax*(1-v) + Cp_metal*v
I would be grateful if you can help me to write the C-code and defined it in Fluent.
maherm is offline   Reply With Quote
melting + vof modeeling for PCM in air taw FLUENT 2 August 24, 2018 00:21
PCM melting inside the Al cavity shoxan FLUENT 1 August 9, 2018 02:12
How can I make the solid PCM to sink to the bottom as it melts? Lim FLUENT 6 December 22, 2014 02:29
urgent need in simulating the PCM rosol FLUENT 2 September 22, 2010 08:14
melting of pcm in cylindrical annnulus? birol FLUENT 0 December 31, 2008 07:42
