Different lift coefficients for different grids for same geona headsail |
June 20, 2012, 11:27 |
Abhipray Jain
Rep Power: 14 |
Hi all,
I imported the same mesh for different camber profiles of the headsail (6 different camber profiles with same mesh) and I changed the grids named Coarse, medium and Fine grid for all 6 cambers. Thus, total number of meshes become 18. After running simulations in Ansys 13.0 fluent I got values for lift coefficients and when i compared the lift coefficients for coarse, medium and fine grids for a particular camber it gives me a value of 1.7444,1.7455 and 1.663876 respectively. For other cambers the values are quite close to each other which is required and a uniform graph can be seen when a graph is plotted between Cl and X/Chord. For analysing any mistake which i may have done in this particular mesh ( fine mesh which gives value of 1.663876) , I made 2 graphs between the Reattachment length and X/Chord : and between trailing edge separation length and X/Chord. Xr Vs X/Chord graph seems okie but Xtes Vs X/Chord gives a zigzag profile for all the 3 different grids. While taking the values for Xr and Xtes , i understood that the values which i take for Xr and Xtes can be wrong as those values are taken on assumptions from the graphs. Another way to find a mistake is to compare the Contours of Velocity magnitude. But I don't know how compare them and how to find the result. These both methods were told by my supervisor and before going to him i want to know if I am doing right thing or not. |
lift and drag coefficients around a ground vehicle | Pedro | CFX | 3 | September 5, 2012 18:31 |
Great lift coefficients but negative drag coefficient?! | nez | FLUENT | 0 | November 28, 2011 13:57 |
how to set lift and drag coefficients in force mon | alagesanj | FLUENT | 0 | November 16, 2008 20:47 |
Lift and Drag Coefficients Reliability | Luis | FLUENT | 2 | December 27, 2005 14:45 |
Lift and Virtual mass coefficients in FLUENT4.5 | Vivek Buwa | FLUENT | 0 | November 7, 2001 08:50 |
