"divergence detected in AMG solver: omega"
Old   June 14, 2010, 05:13
Default "divergence detected in AMG solver: omega"
Jon
Sidewinder is on a distinguished road
I am having a problem with my simulation for university. I keep getting this error:
I have tried changing the relaxation factors for the turbulence and the specific dissipation rate. But to no success. the gas is compressbile and I have specified a mass flow inlet and a pressure outlet. I am using the k-omega model for this simulation.
But i cant seem to get away from this error. I am thinking to turn off the energy equation.
Does enybody have some help or hints for me? I would greatly appreciate it.
Thanks!
Sidewinder is offline   Reply With Quote
Old   March 6, 2012, 16:41
Arun
arunintn is on a distinguished road
I have the same error. I'm doing analysis on T106A turbine blade simuli. I think you have the solution for that. If it so please let me know what is the solution.
Thank you
arunintn is offline   Reply With Quote
Old   March 7, 2012, 00:11
arjun
arjun3020 is on a distinguished road
in URF go to advance settings, and change the cycle to F.
arjun3020 is offline   Reply With Quote
Old   March 7, 2012, 03:45
Arun
thanks for replying.. I have another problem divergence detected in AMG solver: Temperature". I like to know this troubleshooting method. I quit new to CFD.
Old   March 8, 2012, 23:57
arjun
Reduce URf for temperature. and check all Boundary conditions. hope it will help.
Old   March 9, 2012, 05:50
Arun
I solved the problem.. I made some mistake in boundary.. thank you for you help
Old   March 10, 2012, 00:15
arjun
Ok... these are common errors with fluent, to resolve it 1. check URF.
2. Check BC
3. Change advance cycle to F.
Old   March 10, 2012, 05:33
lida
wujinlao5 is on a distinguished road
hi ,man
there are 5 to 6 dropdown list in urf advance setting ,x-momnetum\y-momnetum...
when you say " change cycle to F" for this problem, which one do you refer to?
dont tell me it is the omega relevant one.
2. Check BC
wujinlao5 is offline   Reply With Quote
Old   June 9, 2012, 10:02
Fariborz Soroush
faudiS8 is on a distinguished road
I've the same problem
what do you mean by advanced cycle while there is not such a thing in Under relaxation factors section!?
Thanks for clarification
faudiS8 is offline   Reply With Quote
Old   June 10, 2012, 02:07
Arun
you need to find this option in advanced settings and you'll get a pop-up window.
My case i don't need to switch on energy equation because i'm not finding temperature. My problem converged after i switched off the energy equation. If possible you can tell me what you are doing?
Old   June 10, 2012, 03:35
Fariborz Soroush
hi
I'm modeling combustion and when I change the density calculation method to ideal gas this problem happens. How do I cope with? I let incompressible ideal gas method to iterate enough (about 300) and then it's residuals are little enough. So by changing to ideal gas method, it converges.
but it's still a question for me!
where is the advanced setting option in the window you say!?
Do we talk about the following link's window!?(Under relaxation window)
http://hpce.iitm.ac.in/website/Manua...ution_Controls
thanks alot
Old   June 10, 2012, 04:02
Arun
I have attached a picture file. I think you can find now. Pleas let me know your fluent version. I'm using Fluent 13.
I like to say URF is is an advanced settings. Try to be careful when you work in that.
Old   June 10, 2012, 07:57
Fariborz Soroush
goood!
I found out why! I use Fluent 6.3.26! the last dedicate fluent version)
Ansys in 13 version change it too much! Also I think This option- means F cycle- is available for multigrid, isn't it?
by the way....thank you for your attachment!
Old   June 27, 2012, 04:31
Fariborz Soroush
hi every body
the problem i found! for changing the solver scheme to F-cycle in fluent 6.3.26 you may go to this path:
Solve>Control>Multigrids...>
here a window will be opened and you may change to F-cycle.
Note: I would appreciate any one who help me to find out the exact mechanism change by this method. In the other words I want to know how this mechanism works, why it diverges, and what does this scheme change do. I heard of a CFD book by someone like choe(?!?) on this. but i'm not sure.
Divergence detected in AMG solver: pressure correction jimmer FLUENT 2 August 7, 2010 06:47
AMG solver _divergence detected Shamoon FLUENT 6 March 11, 2009 07:59
Error: divergence detected in AMG solver: temperat Rubén FLUENT 3 December 11, 2007 11:48
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
user defined function cfduser CFX 0 April 29, 2006 10:58
