fluent ansys 14.0 and rendering mesh edge
Old   July 13, 2012, 03:14
Default fluent ansys 14.0 and rendering mesh edge
Laurence Wallian
Laurence Wallian is on a distinguished road
hello,
I have a fluent result (case-data file) and I want to visualize it in GUI.
with the version 12.0, it was possible to only show the edge of the geometry before define filled-contour to see the field of velocity, pressure... on faces or defined surfaces
the commands was :
  • /display/set/contours/render-mesh? yes
  • /display/set/filled-mesh? no
  • /display/set/mesh-partitions? no
  • /display/set/rendering-options/surface-edge-visibility yes no no yes 2
  • /display/set/mesh-surfaces list_of_surfaces_to_show ()
  • /display/zone-mesh ()
but today, the same commands don't work anymore : nothing appears on the screen
does anyone know why ?
thank you for your answer
Laurence Wallian is offline   Reply With Quote
Old   July 13, 2012, 05:01
Default TUI changes between versions
Marion
Marion is on a distinguished road
Hi Laurence,
I don't have V14, but I found out that the TUI commands changed between V12 and V13 - my journal files written in V12 had to be changed when I moved to V13.
Maybe that is also the case with V14?
You can have a look at the help where you'll find the list of text commands available, you'll probably find out where your commands are now!
Regards,
Marion.
Marion is offline   Reply With Quote
Old   July 13, 2012, 07:58
Laurence Wallian
thank you for your answer.
I used the v12 release before installing the v14 too, and I've also noticed some differences between these two releases
but, in this case, what is strange is that when you are using GUI, no edge appears on the screen, and when you use the same commands inline (fluent 3d < commande_file, with the commands written in the file commande_file) the resulted figure (/display/save-picture figure_name) have the edges drawn !
so I suppose it's an error in the GUI of the new release !
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
CFX-Pre problem, pls help!!! cth_yao CFX 0 February 17, 2012 00:52
Ansys CFD + rendering farm nolga ANSYS 3 July 1, 2011 13:40
Rendering Fluent Data in Paraview burk FLUENT 4 July 7, 2008 03:32
