Dynamic mesh problem
Old   June 9, 2016, 04:19
Default Dynamic mesh problem
Uroš Kočevar
entlit is on a distinguished road
i am writing this post because i can not find the solution to my problem. I hope any of you guys know the answer.
I am trying to analyse the heat conditions in compressible fluid (helium) and how the heat is transferred to the surrounding wall.
I am having a trouble regarding dynamic mesh simulation. The problem arises when i try to preview a mesh motion under Dynamic mesh panel. I want to use Layering method with block structured mesh created in ICEM. When i run mesh preview some vertices stay connected with the vertices on the wall. Regardless what settings i use i can not disconnect vertices on the wall and piston.
This is just a simple 2D example that i wish to solve before moving to original 3D problem. I hope you know what i am doing wrong.
entlit is offline   Reply With Quote
Local mesh refinement definition in a DEFORMING dynamic mesh zone using Dynamic Mesh Emanuele88 FLUENT 0 February 9, 2016 11:39
Update of the variables after dynamic mesh motion. gtg258f OpenFOAM Programming & Development 9 January 18, 2014 10:08
Dynamic mesh update problem. David FLUENT 3 March 15, 2012 05:02
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
CFD-3D flow problem using Dynamic mesh method. Sar_mech FLUENT 1 November 27, 2008 21:17
