problem in setting environment in fluent 13.0
Old   July 27, 2012, 06:49
Default problem in setting environment in fluent 13.0
ravindra is on a distinguished road
hi friends,
i am using ansys fluent 13.0 and i want to compile a udf ....but i think there is some environment problem...Can anybody tell me how to set environment in fluent 13.0...
note:- i have installed visual c++ express 2010
ravindra is offline   Reply With Quote
Old   July 27, 2012, 08:05
Default Compiling UDF
Amanda Maria Bizzinotto Ferreira
AmandaMBF is on a distinguished road
Send a message via Skype™ to AmandaMBF
Hello Ravindra,
Here are some cares you have to take to compile a udf to fluent succefully:
1 - You must have Microsoft Visual Studio installed preferable on C: drive;
2 - The udf file must be in the same directory as fluent case and data files;
3 - Don't use dashes or spaces when naming neither your udf file or your working directory.
These things can cause errors. If you have any doubts take a look on these websites, they have good tips about compiling and interpreting your UDF file:
https://www.sharcnet.ca/Software/Flu...df/node130.htm
http://202.118.250.111:8080/fluent/F...udf/node15.htm
Hope it helps you,
Amanda
AmandaMBF is offline   Reply With Quote
Old   July 27, 2012, 08:38
Default you must start ansys cmd shell.
Kijung Ryu
Kijung Ryu is on a distinguished road
I attached pdf file. follow this document.
good luck.
Kijung
Kijung Ryu is offline   Reply With Quote
compile a udf
MPI problem with fluent aryanet FLUENT 17 October 30, 2017 21:04
Problem about Fluent on Linux hbinma FLUENT 3 July 6, 2008 10:49
Need help in setting up a shock tube problem kalee FLUENT 0 November 2, 2007 14:11
UDF problem caused by various version of Fluent Yurong FLUENT 3 January 15, 2006 10:57
Gambit Meshing export to fluent minor problem John c. FLUENT 2 February 6, 2002 16:52
