DPM post processing
Old   August 1, 2012, 07:13
Default DPM post processing
barzin
barzin is on a distinguished road
Hi guys!
Can anyone tell me how can I get a contour of a particle variable (more specifically particle velocity magnitude or diameter) on a specific plane in FLUENT!
Your prompt response is most appreciated.
Bests
barzin is offline   Reply With Quote
Old   August 1, 2012, 14:48
Mosi Owa
BMCombustor is on a distinguished road
Originally Posted by barzin View Post
Hi guys!
Bests
Go to Graphics and Animation>Particle Tracks
Then choose "point" from "Style" drop down panel and select "Particle Variables..." from "Color by". The only remaining part is to select the property you'd like (Particle Residence Time, Particle ID, Particle Diameter, etc.). Also, don't forget to choose your injection from "Release from Injections".
BMCombustor is offline   Reply With Quote
Old   August 1, 2012, 14:56
barzin
Hey pal,
Thank you so much for the reply. Well the problem is I can't see the variable of interest on a defined plane. Like in a way that you define a plane/line and see the variable changes on the specific plane. In the particle variable there is no option to define a surface and see the particle variable changes on there? any suggestion?
Old   August 1, 2012, 18:10
Mosi Owa
Hey pal,
Now I got you; but do you think it is feasible to display particle (a 3D medium) on a plane which is a 2D space? That's probably why Fluent doesn't have any option to track particles on a plane.
Old   August 2, 2012, 09:11
barzin
Thanks alot for the reply. Fair enough since you've got a point there. May be and since the particles are infinitesimal medium, they are not to be sliced!!! Any how, what about another way of post processing? Is there any way that I see the rate of variable changes through a sample surface/volume of my computational domain? I mean, say some particles injected through my domain and I want to see the diameter changes of a group of them before(X0) and after(X2) a specific point (X1)? where [X0<X1<X2]
Old   August 17, 2012, 04:00
htnyc is on a distinguished road
I'm having similar problems as well. I need to create sampling planes to obtain the rate of particles flowing through these two planes(at two different outlet) , with units of kg/m2. How is that possible? I couldnt find any options in the particle tracking, i would really need to get some help on this..
I'm running transient on dpm model
htnyc is offline   Reply With Quote
Old   August 17, 2012, 04:57
barzin
Hey.
I think I know what we could do...
make your planes and before start the calculations got to reports> sample, Pick your planes of interest and then > press start. Fluent save the particle data (e.g. diameter, position ...) when the injection interacts with the plane. Then you can read it back via Histogram in report>Histogram. Read back the planes and you can see variable of interest in a histogram mode. I'm not sure how can you obtain all particle data. please let me know if you figured something and hope this helps
Old   August 17, 2012, 09:25
THanks, i will try that out. Do u know how i could make an plane in a circular pipe? (for sampling)
I tried using the iso-surface but..I couldnt figure how to adjust the slider and settings in order to get a plane within my pipe's cross section. Is that even possible?
thanks so much.
Old   August 17, 2012, 09:27
barzin
go to surface>plane and specify your plane. You don't need iso surface
Old   April 22, 2015, 03:08
hossein
hzeidabadi is on a distinguished road
Hey pal,
hi
check ''mean Values'' in "contour plots for DPM variables" at the Discrete phase model menu to see "Discrete phase variables"
hzeidabadi is offline   Reply With Quote
post processing for CEL expressions Niru CFX 0 May 10, 2013 13:13
Automated post processing using CFD Post shreyasr ANSYS 0 January 28, 2013 06:21
[OpenFOAM] is parallel processing available in parafoam for post processing? sachinlb ParaView 1 August 14, 2012 09:52
fluent for post processing James FLUENT 0 April 21, 2006 04:43
post processing in CFD MANISH BHARGAVA Main CFD Forum 0 October 17, 1998 20:51
