Considering the flow through a dense net / grid |
July 31, 2012, 15:05 |
Rep Power: 17 |
I have a grid like structure in the flow path and I'd like to consider it's effect with out actually meshing it.
The attached image shows the sructure / surface im talking about. I'd like just keep it as a plane surface with out actually meshing those small holes but considering their effect by some means. Could some one please tell me how to do this.
Best regards, Santhosh. |
August 1, 2012, 03:07 |
Flavio
Rep Power: 15 |
Hi saisanthoshm88,
in the past I worked on a burner with a very dense metallic net: I modelized it with porous zone, so I suggest using it (even porous jump can be used). See Fluent Manual for info about it (if you'll have some specific question maybe I''be able to answer ) Regards |
August 1, 2012, 05:58 |
Rep Power: 17 |
Yaa I think the porus jump boundary condition could be used here but I didn't know how to calculate the face permeabilty and pressure jump coefficient to my case.
I don't know the velocity of flow through this perforated plate it's just lying in the flow path. Could some one please suggest on this
Best regards, Santhosh. Last edited by saisanthoshm88; August 1, 2012 at 09:07. |
August 1, 2012, 10:27 |
Flavio
Rep Power: 15 |
Perhaps you can find some empirical correlations about velocity and pressure through a grid like yours...
Or you could model a small fraction of the system (maybe taking advantage of symmetries) and simulate it with a good mesh even for the holes
Bionico |
On grid independent solution for pulsatile flow | David | FLUENT | 5 | March 25, 2022 03:33 |
Grid independent problem for lid-driven flow | dpc-buaa | Main CFD Forum | 0 | February 22, 2011 22:24 |
[blockMesh] Grid generation cross flow over circular cylinder | Yanma | OpenFOAM Meshing & Mesh Conversion | 0 | July 7, 2010 08:02 |
Grid for swirling flow | Stephen | Main CFD Forum | 6 | October 24, 2008 17:57 |
computation about flow around a yawed cone | Tylor Xie | Main CFD Forum | 0 | June 9, 1999 07:33 |
