How to rotate a geometry in gambit
Old   August 3, 2012, 10:32
Default How to rotate a geometry in gambit
Mahmud-Ul-Hasan Muneem
jester09 is on a distinguished road
I want to simulate a cavitating flow around a naca 0015 hydrofoil at an angle of 6 degree.I can make the angle by changing the x/y component of the velocity.but i would like to rotate the whole hydrofoil by 6 degree.can anyone suggest me the commands that will rotate the geometry without changing the allignment of the mesh.Thanks in advance.
jester09 is offline   Reply With Quote
Old   August 6, 2012, 00:17
Ganapathy Iyer
Ganapathy is on a distinguished road
You can create the mesh and then rotate the whole volume using the (with mesh) option.
or you can do it in Fluent itself
Ganapathy is offline   Reply With Quote
Geometry of Tank and Rushton Turbine in Gambit jawidnaik ANSYS Meshing & Geometry 1 February 4, 2015 07:28
create turbine geometry with gambit badlaine ANSYS Meshing & Geometry 2 March 26, 2012 23:54
What can I employ to create geometry besides Gambit? summer ANSYS Meshing & Geometry 2 February 11, 2011 14:50
vitual _ real deneb FLUENT 3 January 22, 2007 04:31
problem about Importing geometry in Gambit Hua Gu FLUENT 3 April 2, 2002 14:24
