How to set the parameters for the Boussinesq Model in the fluent |
August 28, 2012, 22:35 |
Fangdian
Rep Power: 13 |
I want to simulate the welding pool(which comes from the molten steel for the heating of welding arc to the melting steel plate) in the arc welding, taking the natural-convection flows in the welding pool. I use the VOF and solidfication & melting model in my case and I want to consider the buoyancy with the Boussinesq model in the fluent as follws: In my case, there are two phase which are the ideal air(primary phase) and the steel(second phase). I have set the solidus temperature as 1773K and the liquidus temperature as 1793K. The density of the steel and ideal air are 7860kg/m3 and 1.225kg/m3. The thermal expansion coefficient of steel is 1e-4. With respect to my case, how to set the parameters for the Boussinesq model? I can set the density of the flow with the density of primary phase, that is to say,the density of the ideal air 1.225kg/m3. But how can i set the is the operating temperature, the solidus temperature or the liquidus temperature of the steel plate(the second phase) in the expression above? Thanks. Last edited by fangdian; August 28, 2012 at 22:37. Reason: format of the text |
boussinesqsimple, operating density |
Evaporation model in ansys Fluent 12.1 | oldisbest | Fluent UDF and Scheme Programming | 12 | March 26, 2020 09:11 |
Can FLUENT model flashing liquids? | SWK | FLUENT | 9 | June 22, 2017 01:17 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
Reynolds Stress Model in Fluent Vs CFX | Tim | FLUENT | 0 | December 6, 2005 22:03 |
How to set turbulence parameters at periodic BC? | Ray | FLUENT | 2 | July 28, 2000 04:15 |
