asymmetric 2d diffuser boundary condition
Old   August 25, 2012, 09:05
Default asymmetric 2d diffuser boundary condition
achille89 is on a distinguished road
hello i'm trying to solve a 2d asymmetric diffuser in ansys 12. Steady flow, constant density, pressure based, turbulent k-e model.
Some questions:
1 - as boundary condition i've chosen velocity inlet and outflow.
i didn't choose pressure outlet because i think that if i fix the pressure i will obtain an unrealistic solution because in this way the system is forced to reach the pressure that i established. it is a good consideration?
2 - i have to use the standard wall function and then enhanced wall function. in the first case y+ must be around 30 so what you advice about mesh?
thanks
achille89 is offline   Reply With Quote
Old   August 29, 2012, 08:03
hello new problem: i'm trying to solve the problem with k-e enhanced wall. A strange thing happened: i've done 3 meshes (350x200, 350x250, 350x300) and i'm trying to obtain mesh independence results. The 3 mesh above give similar result but when i solve a finer mesh 350x350 the solution completely change!!! how it is possible?
Old   September 1, 2012, 07:29
help please
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
inlet velocity boundary condition murali CFX 5 August 3, 2012 08:56
Setting outlet Pressure boundary condition using CAFFA code Mukund Pondkule Main CFD Forum 0 March 16, 2011 03:23
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 11:44
Spectral Method Boundary condition Deepak Main CFD Forum 1 February 25, 2004 09:48
