problem Using Matlab for post processing
Old   September 4, 2012, 16:20
Default problem Using Matlab for post processing
Negin Nazarian
nenazarian is on a distinguished road
Hi
I wrote a function in MATLAB that would open different Case/Data files in a specified format and export the results and close it.
I used a "for" loop that writes a journal for each case and execute fluent with that. The problem that Im having is that is doesnt wait for fluent to export the result before doing the next loop and this means it attempts to open Fluent in all cases all at once.
does anyone know how to fix that? Is there any way to only go to the next "for" if fluent is done exporting and its closed?
thank you in advance for your help
cheers
Negin
nenazarian is offline   Reply With Quote
Old   September 6, 2012, 15:00
Negin Nazarian
Any help is appreciated.
I have so many runs to post process and the export function in matlab in giving me a headache.
Old   September 6, 2012, 15:56
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
Instead of let Matlab open Fluent and run a journal, let Matlab create a journal which, once read in Fluent, will open all the cases doing the required job for each of them.
sbaffini is offline   Reply With Quote
Old   September 6, 2012, 16:41
Negin Nazarian
Wow! I didnt thought of that!
Thanks again paolo
Cheers
Negin
HLL Riemann Shock Tube Matlab Problem Luke F Main CFD Forum 2 May 20, 2016 02:10
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 19:42
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 05:29
parallel processing problem with multiproc machine hajra_rabaeto!!!!!!! FLUENT 2 January 28, 2006 19:11
Post processing display problem Jennifer Haque CFX 2 January 18, 2002 11:01
