Modeling particle filtration
Old   July 20, 2012, 10:25
Default Modeling particle filtration
Fernseher is on a distinguished road
I'm trying to simulate water flow through a filter element. The water contains small particles (10µm diameter) which should be filtered out. The filter is set as a thin porous media zone. The volume fraction particles/water is about 2e-5 at the inlet.
My goal is to visualize the accretion and distribution of particles on the filter. I'm not sure which model would work best. Should I use the eulerian-granular multiphase model, and set different viscious and inertial resistance values for the different phases? I tried this, but didn't get good results yet. Even when I'm using the same resistance values for both phases, the soultion doesn't converge.
I also tried the discrete phase model, but I think the volume fraction close to the filter gets much higher than at the inlet, so the multiphase model should be the right one.. ?
Fernseher is offline   Reply With Quote
Old   September 10, 2012, 06:47
Or could I use an UDF to simulate the filter barrier?
Blood Damage Modelling via Particle Tracking in a Centrifugal Heart Pump scatman CFX 7 January 8, 2018 00:59
modeling particle transport in ansys cfx 10.0 siavash CFX 9 November 23, 2010 21:21
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
Spray and Particle Flow Modeling for Automotive Ap Flok FLUENT 0 May 1, 2006 14:58
Particle modeling query Steven CFX 1 December 2, 2005 05:29
