fluent 5 3d model
Old   September 14, 2000, 10:52
Default fluent 5 3d model
mike
hi pple,
i am using fluent 5 to predict the pressure distribution of lubricant in a plain journal bearing. i have encountered reverse flow at the certain face located near the pressure inlet (boundary condition) .this occur when i initialise the solution and iterate it with four boundary conditions.(journal-wall,bearing-wall,pressure inlet and pressure outlet).this reverse flow might occur at pressure outlet.laminar flow. i am working with atmosphere pressure(101.3kpa) at the inlet(gauge).zero gauge at the outlet pressure.journal is rotating while bearing is stationery. pls give me some advice to solve this problem.thank you.
Old   September 14, 2012, 01:33
Red face
Dinesh
Dinesh_Dhande is on a distinguished road
I am also facing the same problem.
Dinesh_Dhande is offline   Reply With Quote
Seeking Macroscopic Particle Model in Fluent bzhang7 FLUENT 3 June 25, 2022 17:54
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
H ow to compute the model by FLUENT and ANSYS njiit FLUENT 0 March 2, 2010 22:24
Fluent 12 k-w SST turbulence model DarrenC FLUENT 0 December 13, 2009 08:33
Covert Star-CD model to FLUENT Lam Siemens 6 June 24, 2003 20:21
