time step size too small???
Old   September 12, 2012, 11:53
Default time step size too small???
Lilly is on a distinguished road
Dear all,
I have got a question concerning the proper choice of the time step size:
I run a simulation and after about 25 iterations my residuals look like this (this is an example showing about time step number 600):
Updating solution at time levels N and N-1.
done.
iter continuity x-velocity y-velocity z-velocity magnevist time/iter
! 9213 solution is converged
9213 5.5898e-14 8.0432e-15 5.2701e-15 8.5588e-15 3.8219e-04 1496884126130134:11:12 1000000000000000000
! 9214 solution is converged
9214 5.5662e-14 8.0247e-15 5.2200e-15 8.5326e-15 3.8221e-04 1498709810042426:35:44 999999999999999999
step flow-time inlet lad lcx lmca_025
The Fluent manual says that ideally there should be about 5-10 iterations per time step, otherwise one should increase the time step size.
Does it have influence on the solutions if my time step size is too small and if I have few iterations therefore?
Thank you for any help!
Lilly
Lilly is offline   Reply With Quote
Old   September 15, 2012, 00:51
kbaker's Avatar
Khalid Baker
kbaker is on a distinguished road
If you increases the time step the number of iterations per time step increases it not should be too large approximately 0.01 s is good (be aware your solution should convergence if you increases it else you must decreases it until you get convergence) it just make your solution run faster with time.
kbaker
kbaker is offline   Reply With Quote
Choosing the apt time step size for a transient run saisanthoshm88 CFX 1 March 31, 2012 16:11
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
Navier-Stokes time step size Martin Main CFD Forum 2 June 6, 2008 03:38
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
