October 8, 2012, 04:39 |
CFD Analysis of Airfoil at Mach = 0.0
Ali
Hi folks
I want to perform a 2-D airfoil CFD analysis at Reynolds number of 9.0M and Mach number 0.0. Is this possible?
Best Regards Ali |
October 8, 2012, 04:47 |
Philipp
Rep Power: 26 |
No.
Check your numbers, there must be a typo. Mach number = 0.0 means your velocity is zero. |
October 8, 2012, 07:46 |
Stuart Buckingham
Rep Power: 26 |
Technically yes, as the Mach number is just a function of the compressibility of the fluid. If you have not turned the energy equation on, the physics modelled disregard any compressibility effects, and therefore Ma = 0. Effectively, the bulk modulus and ratio of specific heats go to infinity; but your velocity can still be non-zero.
You can set your Re by changing the fluid viscosity, scaling the model (to achieve a specific L) or modifying the velocity. Assuming Ma = 0 for low Ma numbers (~<0.3) is common and generally accepted within the industry. Hope this helps, Stu |
October 8, 2012, 07:57 |
Philipp
Rep Power: 26 |
Ok, thats true. If you have M = v/a with a = infinity. But if you artificially remove the speed of sound from your equations, it does not seem appropriate to me to use the phrasing "Mach number" at all. Maybe this is the common practice .
October 8, 2012, 08:07 |
Stuart Buckingham
Rep Power: 26 |
Rodriguez,
You're right, I think it is quite illogical to think of modelling a flow with Ma = 0.0; but I bet if Ali had said "incompressible flow", you would have no problem realising what he meant. Ma = 0.0 is just a bad (or at least, unnatural) way of saying flow is incompressible! Stu |
October 8, 2012, 08:11 |
Philipp
Rep Power: 26 |
Absolutely! I'm no "airodynamics"-guy, so thanks for the free lecture
October 8, 2012, 10:19 |
What if, you put the very very very large enclosure (order of 500 as compared to body characteristic length) and specify the same static and total pressure (101325 pa to be specific)?
In fact we did this for the Fan simulation, by specifying this condition so that we can truly model the engine and atmosphere. Although the flow in the vicinity of fan was not with Mach = 0.0. Therefore it is just a technique to model the flow with real boundary conditions. What you guys think about this? |
October 10, 2012, 22:49 |
#8 | |
Ali
Flow is incompressible (M < 0.3), So what will be the velocity then for M=0.0.
Best Regards Ali |
October 11, 2012, 05:40 |
Philipp
Rep Power: 26 |
[blockMesh] could anyone post a simple cylinder mesh | guilherme | OpenFOAM Meshing & Mesh Conversion | 46 | October 23, 2020 17:18 |
Urgent Naca4415 | ck3 | FLUENT | 3 | June 9, 2012 08:36 |
problem in running icoFoam | Alucard | OpenFOAM | 2 | March 17, 2012 09:01 |
FDM vs FVM vs FEM in CFD analysis | ck5285 | FLOW-3D | 1 | September 1, 2009 10:51 |
correction of KIVA Itape | hama | Main CFD Forum | 0 | May 2, 2006 03:41 |
